Old 06-10-2007, 06:22 PM   #1
Kuban
Default WOW abrupt engine issues on new jasper.
Yea so i installed a new jasper longblock about 3600~ or so miles ago. Yesterday i did one full low boost pull (12psi) and i started smoking like crazy. Keep in mind i rebuilt my turbo like 3 days ago. I pulled over and checked it out. No oil leaks anywhere, but when i pulled the oil filler cap off, i had a little bit of combustion gas comming out of the pcv block tube. Not good. That right there is a for sure sign of blow by. How the hell does a brand new jasper engine help put together by a master toyo tech, completely properly broken in , have blow by? Im curious, cause this would be the second jasper engine i have had rings go on me within the last 4 months. Kinda pissin me off now. I dont think the turbo is what smoking due to the simple fact that theres blow by. If there was no blow by, then i would say its the turbo all day long.
I need input and recomdations please.
With the new jasper engine i was given a compete engine gasket set that we used to the fullest, new oil pump, and a procedure to flush out the oil cooler. So that system was checked, a checked,nd checked again.
p.s. after it started smoking the engine had a new tone to it. Sounds like a miss, also had obvious loss of power. I think i may have fouled a plug. But that doesnt cause blow by that im aware of
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Old 06-10-2007, 07:08 PM   #2
supramacist
supramacist's Avatar
It's these cars man. It doesn't matter what you do to them they are just jinxed into the worst case scenario slot. This is the only logic I can lay on it.
Old 06-10-2007, 07:35 PM   #3
Kuban
touche`
I looked deeper into it (LOVE DOING THAT ON SUNDAYS!!!! NOT!~@#$%^&), seems as though my pcv tube was kinked a bit kinda cutting off flow to the intake and ruining the vacume. I took it for a test drive and its not smoking anymore. But that doesnt change the fact that there are combustion gasses blowing by. It still sounds like it has a miss. But it does have standard plugs in it. So im going to put these iridium 9's i got chillin here in and change the oil. Might even do a comp test while the plugs are out. Ill keep ya all updated.
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Old 06-10-2007, 10:43 PM   #4
Kuban
Well i was talking to my toyo tech, he mentioned if the pcv airway was blocked for a long time, the excesive crankcase pressure could possibly crack a ring under a hard enough load. This coule be my issue. Anyone else think thats possible?
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Old 06-11-2007, 12:24 PM   #5
if it was blocked then boost would be entering the block depths, it was only one run tho, and small blow by is normal
do a compression check and let us know the numbers
Old 06-11-2007, 04:07 PM   #6
Kuban
Ran a comp test last night when i changed out the plugs. Numbers went as follow from 1-6
175
175
175
175
110
175
As you can see 175 for dry compression test is right where i want to be although cylender #5 is dead. Im guessing ring damage. Thing is, If the backpressure was so hard i would have blown seals on the engine long before i would have cause this kind of damage, but it happened noticeably right after the race. On the last engine when all the rings were gone, i litterally poped the front main seal off the last time i ran it. Dont get me wrong i dont beat my cars by any means. I baby them unless im racing someone and thats about once a week tops.
Looks like its time to call jasper and see if im warrentee.
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Old 06-11-2007, 06:44 PM   #7
supradaddy0803
supradaddy0803's Avatar
Well with all that increased pressure then you will have heat and if there was a backup then a soft part will go. Piston rings are strong up to a point but with more pressure than they can handle then they will fail. I had a PCV issue on my 86.5 and it ended up the head gasket was marked this side up on the wrong side and the oil drain back holes ended up being PCV vents pushing the gasket out. But with that low number on your #5 it has to be the rings if they got hot enough it may have coked oil in the ring grove and stuck the ring all the way in it could happen seen it on chevys before with a guy running nitrous and a supercharger kinda crappy really.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 06-12-2007, 09:03 PM   #8
IHateHacks
IHateHacks's Avatar
So you are running 12psi on a stock fuel pump and stock injectors?
I personally think that is what caused your problem, too much boost not enough fuel, but its weird how only 1 cylinder got affected.
Either that or Jasper just don't make good 7M's.
Old 06-13-2007, 02:49 AM   #9
Kuban
Well i dont know man, on the previous tune it was set at 12psi and on the dyno the afr was holding low 12's. I could see if i did have a lean situation in only cylender 5, such as a stuck injector, it could have detonated and bent the valves causing them not to seat correctly. Alot of things could have happened, but one things for sure, since it is only in cylender 5 my guess would be there is something wrong with the injector or wires on that injector causing this. Only other possibility is manufacture defect.
Keep in mind the comp test i did was dry. 175 across all the cylenders dry except one is pretty damn good. If it were some outside influence causing this i think more than only one cylender would show exessive wear.
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Old 06-13-2007, 04:03 PM   #10
supramacist
Not to be rude or anything but you should stop talking about it here and start talking to jasper engines. No malice intended. Don't waiste another day of the warranty.
1990 supra turbo engine issues help jespat Non-Generation Specific Questions 4 01-24-2008 02:37 AM
90' engine in 87' w/ tranny issues. chash360 MKIII Supra 2 12-11-2006 05:39 PM
