Old 06-09-2007, 12:42 AM   #1
Donovan
Donovan is on a distinguished road
Default starting problems
well one day when i hooked up my air fuel ration gauge my car ran fine for the first day then the next day when i went to start m car agin it wouldnt start so i was searching for an hour until finally i came across that the efi fuse blew so i replaced that and unhooked the air fuel ration gauge cause i had a feeling that that was the culprit of the whole problem and now since then whenever i go to start my car after it has sat for like overnight it takes the car forever to start up it sits there and tries o turn over for at least 8-12 seconds before it actually starts but then after that i am able to actually start it up all day with no problems unless it sits over night
has anyone ever heard this happening or has it happened to you if so input would be greatly appreciated so i can try to figure out my problem i have here thanks
Nash™
www.myspace.com/devoted_seth07
Donovan is offline   Reply With Quote
Old 06-09-2007, 08:55 AM   #2
f00g00
You can try connectiong the guage through its own fuse instead of adding it to the EFI one. If you start adding components to an existing system that was determined from the factory to run a certain fuse then its possible that you are overloading the system but I can't see a guage doing that.
Might the guage be connected to the oxygen sensor and now that the guage is disabled now the oxygen sensor is too? Im not sure if that will have an affect on starting but it certainly will affect it during running if there is no feedback to the ECU. Im not sure if the ECU has a default if the sensor is disabled but it will run too rich,
You can also check the cold start injector and see if it crapped out. You can remove it from the intake manifold when cold, shove it in an empty plastic bottle to help contain fuel spray and crank the motor for a second and see if it sprays, if it does then you might have a weak fuel pump which could be why it takes the 8 - 12 seconds to start. There are steps in the TSRM to check fuel pressure.
Old 06-09-2007, 05:53 PM   #3
Donovan
i know that the gauge is not hooked up to the efi fuse its just somehow the fuse blew by itself but ill try hooking the gauge back up and see if it functions correctly but last time it did that the gauge was misreading cause no matter what i woul always be up in the rich section at the highest point
Nash™
Starting Problems turbo jim MKIII Supra 7 03-30-2009 07:09 PM
cold starting problems Cjanik MKIII Supra 9 08-02-2008 06:50 PM
Starting problems and accleration problems! alekjame22 MKIII Supra 6 03-17-2007 11:19 PM
Starting Problems Nova504 MKIII Supra 6 11-14-2006 08:14 PM
Starting problems HELP adellicson MKIII Supra 0 05-08-2006 03:42 AM
