Old 06-04-2007, 10:04 PM   #1
DavidLeClair584
DavidLeClair584 is on a distinguished road
The question is... if it does have a bhg do I want to get it fixed -.-'' I love driving my supra, but repairing it costs more than I bought it for.
David.
DavidLeClair584 is offline   Reply With Quote
Old 06-04-2007, 10:31 PM   #2
dcrusupra
dcrusupra's Avatar
Yea, thats usually what happens. If it has it, the time has come to decide if you want to fix it and keep it or try to sell it off.
New Rebuild
My CarDomain
Old 06-05-2007, 09:42 PM   #3
IHateHacks
IHateHacks's Avatar
It's a manual GTE, fix it. Its worth saving. Its really not that hard to fix a blown head gasket on these things.
If you see white smoke coming from the exhaust in summer temperatures, you have a problem. Oh wait I just saw you are from alaska, nevermind!
Old 06-06-2007, 06:11 AM   #4
DavidLeClair584
Lol. Well, today I made up my mind. I was driving my friends '93 civic, and then a '90 mazda, and decided I have to fix the Supra. IHateHacks, I saw the thread where you replaced your head gasket, mind sending me the parts list? I can't afford to have someone fix it, and I've managed to scrape together around $1,500 for the repair... Joy. Supras are just to fun to drive.
Old 06-06-2007, 06:23 AM   #5
supramacist
supramacist's Avatar
If you need help with a parts list...., you may be in over your head.
In short you replace everything that could possibley ever again give you problems. Upper gasket set. Spark plugs and wires. MHG. ARP. Molly.
Machinist. Starter, you definitley want to replace this while the head is off.
Assorted hoses. Anything that is rubber that has solidified, gets replaced.
Oil and filter. This is just an off the top of the head list, my build list is a bit more detailed.
1.5k isn't going to get it done. The cheapest you can do a BHG on an n/a is right at 2k. 1800ish.
Good Luck.
Old 06-06-2007, 06:27 AM   #6
DavidLeClair584
Way to go and thrash what little confidence I had. Thank you very much. And I have a turbo... This week keeps getting better.
David.
Good Luck.
Old 06-06-2007, 03:30 PM   #7
supramacist
Confidence???
Don't worry man. These cars are easy enough to work on. It's not hard to repair the BHG. But as I said. Your'e going to need to by a vowel first so you'll have an idea as to what you are in for.
How do you plan to prep your block? Who's going to machine your head.
Parts lists are different for every one. Each of these cars needs something different.
It's going to take you some time. I planned my build down to the wire and I spent the better part of a year doing it.
It' nerve wracking enough with an idea of how things go and keeping track of everything..
My advice to you new guys is do your research and try to buy auto's you can work on yourself, or buy something new and just let the dealership do what you want to it.
You will be wanting a tsrm. Is the engine stock or is a transplant?
You may as well replace the timing belt and be carefull removing the crank pulley, they are fragile, and expensive to replace.
Bhg???? Over heating maybe head gasket? Thermo? AlexSchuSupra MKIII Supra 2 03-08-2009 02:12 PM
over heating problems, need help turbo_mk3 MKIII Supra 5 01-08-2009 05:04 AM
Help! Losing water and over heating, but no dripping?!?! Moses76 MKIII Supra 5 04-06-2008 12:32 AM
Another over heating problem.. newbsupra MKIII Supra 3 05-25-2006 08:26 PM
Heating problem Lee MKIII Supra 3 10-04-2005 11:50 AM
