Old 05-24-2007, 04:16 PM   #1
D_Train
D_Train is on a distinguished road
Default valve cover gaskets are leaking
I brought my car in to get a checkup and they told me
$348.63 to fix.
What are they, is that too much to pay, can i do it myself, what risks do i run right now?
In addition they tell me that soon my drive belts will need replacing. Again, can I do that myself, what risks do i run, what parts will i need, etc.
$150 for them to do it.
D_Train is offline   Reply With Quote
Old 05-24-2007, 04:55 PM   #2
dcrusupra
dcrusupra's Avatar
Thats a lot of money to fix valve cover gaskets.
Get these, call toyota and get the valve cover gaskets and do that yourself. It's not hard. Just remember where all the vacuum hoses go.
The belts arent that hard either. Just get the correct sizes and replace them. Everything should be around $150 if you do it yourself. Belts are probably gonna be $25-30 (3 of them) each, i think the gaskets are $20 each, and those bolts are $32.
New Rebuild
My CarDomain
Old 05-24-2007, 05:09 PM   #3
D_Train
Now keep in mind i've never done anything like this before. I have changed oil and spark plugs and flushed the radiator and changed lightbulbs, but no engine work like this. If I have the supra manual and some elbow grease I should be able to do it? I don't need another person or anything?
Any word on the risks I run right now?
Old 05-24-2007, 05:16 PM   #4
dcrusupra
dcrusupra's Avatar
Well if you've changed the spark plugs, that means you've taken off part of the intake. Its not hard getting the valve covers off. Just do the same like you were going to change the spark plugs. There are 6 screws that hold each valve cover on. Not much room to screw anything up until you start putting things back on and forget where things go. But there are millions of pictures out there of these engines.
The belts are pretty straight forward also. Theres one that goes around the power steering pump and crank pulley. One that goes around the a/c compressor and crank pulley. And one that goes around the alternator, fan, and crank pulley. Which ever one you need to replace, just loosen either the a/c compressor, power steering pump, or the alternator. Problem is they are in a line. I don't remember the order of them but it would be best to replace them all. Again, you wont have any trouble unless you don't remember which belt goes where on the crank pulley. But you'll get it because they wont fit right if one is in the wrong place.
New Rebuild
My CarDomain
Old 05-24-2007, 05:41 PM   #5
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
lucky for me i only got one belt
be sure to clean the surface where the valve cover goes on the head. can used a razor blade or something of that nature. just try not to get any of the old shit in the valve train.
its not that hard. and +1 to remembering where vacuum lines go
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 05-24-2007, 05:58 PM   #6
D_Train
I'll try to see if I can get a friend to help me. If anyone knows the order of the belts let me know. But just to make doubly sure i'm not biting off more than I can chew?
and Actually i feel like such a nubbie that if anyone could post a list of parts that I would need for the repair that would be AMAZING. I hope that my requests aren't ludacris, i don't mean to be a weenie.
Old 05-24-2007, 06:20 PM   #7
dannydavi
dannydavi's Avatar
hey man i got a complete picture set of what to do when replacing valve cover gaskets, it's simple. PM me your email and i'll send you the tutorial. Or you might be able to save this to your comp and zoom it in or something.. http://i156.photobucket.com/albums/t...er_gaskets.jpglet me know if you have any questions, i just did it like a month ago.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 05-24-2007, 06:41 PM   #8
dannydavi
dannydavi's Avatar
List of parts.. hmmm well for the gaskets, all you need are the gaskets. There are 2 of them that come in the box to take care of the valve covers. You also may need a new throttle body to intake manifold gasket if you cant get the old one off in one piece. but you said you did plugs before so you know what gasket im talking about, and it'll prob come off alright. And for the belts i havent personally replaced all my belts but i did have to replace my power steering belt twice thus far, and it is in the back behind the other belts so basically just loosened the belts then put them all back on, pretty simple there to. you should check the belt play with either the SST or a straight edge and measuring device, they are all supposed to be ... here's a link to the spot in the TSRM about the SST and tension. i couldnt find the other method in there, but i believe the tension with thumb pressure left a 3/8 to 5/8 gap, dont quote me though. look it up in your tsrm. hope this helpshttp://www.cygnusx1.net/Supra/Librar...tion=MA&Page=6
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 05-24-2007, 06:56 PM   #9
D_Train
what pages in the TSRM should I concern myself with?
Old 05-24-2007, 06:57 PM   #10
D_Train
for the parts do i just walk into an auto parts store and buy everything or do i order stuff online? :-\ sorry for the nubby-ness
valve cover gasket question? sevenmgte MKIII Supra 8 10-01-2008 06:02 AM
Valve cover gaskets scruffboy Non-Generation Specific Questions 2 04-12-2008 09:27 PM
88 Turbo Leaking Valve Cover Gaskets Sheridan MKIII Supra 1 11-05-2007 01:03 AM
valve cover leaking Supra 90 MKIII Supra 0 10-22-2007 09:35 AM
Valve cover gaskets vancouver874 Non-Generation Specific Questions 7 08-14-2006 07:28 PM
