Old 05-16-2007, 11:02 PM   #1
colin172
colin172's Avatar
colin172 is on a distinguished road
Default How can I tell if the dashboard was out of the car?
I had my Supra at my Toyota main dealer to sort out the common heating problem. They charged me for taking the dashboard out but I then had the car with a specialist who said the dash was never out of the car.
How can I tell if the dash has been out or not?
colin172 is offline   Reply With Quote
Old 05-17-2007, 01:42 AM   #2
IHateHacks
IHateHacks's Avatar
If you can't work on a MK3 supra yourself and you have to take it to "specialists" to "fix" it then you, my friend, should just pack it up and lease a new saturn or a ford something cheap and with a 100K mile warranty.
Theres no way you can tell if the dash has been off unless you did it yourself.
As the old saying goes, if you want something done right, do it yourself.
And don't forget that these cars come stock with a blown head gasket right off the dealer lot. That would explain why you don't get any heat from your heater core. And no theres no way to tell if the head has been off either, unless you did it yourself. Block testers are your friend.....
Old 05-17-2007, 01:45 AM   #3
supramacist
supramacist's Avatar
Look at the screws. Remove it yourself. You'll be able to tell if anyone has been there before you.
Old 05-17-2007, 01:48 AM   #4
Supra2NR
Supra2NR's Avatar
look for missing screws,
on a odd chance maybe they forgot to put it back
but other than that
even if the dealer ddnt open it up
unless ur the first owner of the car, somebody else could have opened it up b4 u
Old 05-17-2007, 01:50 AM   #5
supramacist
I just tend to do $hit the hard way.
Old 05-17-2007, 04:13 AM   #6
Unhappy
What did they say they did to help your problem??
Replace the heater core??
Fix some flapper doors??
Old 05-17-2007, 08:03 AM   #7
colin172
colin172's Avatar
Basically the heat did not come on. The heater control panel turns out to be the problem. The dealer did not replace the panel but instead bypassed the heater control valve in the engine bay. They said they cleaned out the heater matrix and had to take the dashboard to do this.
But when I had the car in with a Supra specialist they said the dash was never out as the screws had the original paint still on them and also the wiring looms/harnesses had not been disturbed. I feel ripped off by the main Toyota dealer. Any advise guys??
Old 05-17-2007, 08:24 AM   #8
Kuban
go cry, and get urself a tsrm. Go to harbor frieght, pick up a basic wrech/socket set for 200$ TOPS. And start your own work.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Old 05-17-2007, 02:13 PM   #9
supramacist
I do everything I can to my car and I attempt things I shouldn't because the only thing you ever know is that you never know.
I won't let the dealer touch my ride Capital F those guys.
I take mine to a couple of former nissan mechanics that have their own shop.
Old 05-17-2007, 04:55 PM   #10
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
i hafto agree w/ everyone.. if you have an mk3 you need to know your shit or have the will to try b/c these cars are unlike any other car you will own and if you pay to have it fixed you are gunna get screwed.
now to add to your topic. being a body man you look for a few things.. but like what was already said anyone b4 you could have had it out and you wouldn't know...its a 20 yr old car it was out at one point.
1st paint chips on factory bolts
2nd loose or missing screws
3rd screws or bolts in wrong place.
4th screwdriver marks around the holes..
5th carpet folded over wrong.
anything out off place will let you know.
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
warning lamp for rear lights on dashboard jarek MKIII Supra 7 10-12-2006 12:17 AM
Dashboard lights JIMMY JAMES Non-Generation Specific Questions 7 08-17-2006 05:07 PM
dashboard problems. anoboss Car Audio and Alarms 0 04-18-2006 01:36 PM
