Old 05-16-2007, 04:44 PM   #11
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
haha my Powersteering pump did as well about 2 or 3 weeks later...so i took off the belt and became old fashion for a couple weeks turns out it was the Rack and Pinion
Supra_87_mk3 is offline   Reply With Quote
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
quick question about water pump supfoo514 MKIII Supra 2 07-22-2006 06:17 PM
Replace Water Pump? Benesesso MKIII Supra 3 03-31-2006 12:26 AM
1gte water pump streetbeast MKIII Supra 15 06-24-2005 08:02 PM
