Old 05-16-2007, 01:11 AM   #31
Z'mnypit
Z'mnypit's Avatar
Z'mnypit is on a distinguished road
SHE RUNS! And pretty strong. Thank the lord. No more SES light. Did the knock sensor rewire mod without having to remove the starter and all is well now. Going to shim the wastegate a little tommorow and she how it does. Only running around 5psi right now. Also going to dial in the timing 1st.
Thanks!
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
Z'mnypit is offline   Reply With Quote
Old 05-16-2007, 01:29 AM   #32
IHateHacks
IHateHacks's Avatar
Thats funny, I could not even remove the rear knock sensor connector with the starter bolted in. Kinda makes me wonder......
Glad you got it fixed. But only 5 psi? These cars run 7psi stock so you might have a vacuum/boost leak or your turbo might be saying bye-bye......
Old 05-16-2007, 05:01 AM   #33
supradaddy0803
supradaddy0803's Avatar
I am glad you got it worked out, I am not sure I was much help just throwing ideas out there and stuff.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 05-16-2007, 01:14 PM   #34
Z'mnypit
Z'mnypit's Avatar
I dont know man, it took a little wiggling but I had it out easily in less then 2min.
Turbo seemed with in spec of the TSRM, the shaft had minimum play. The boost may be going that high, the gauge may be messed up. I noticed it had a little delay. Also I know the timing isnt exactly right. But now that its running Ill start dialing in the small things. Thanks for all the suggestions!
Old 05-18-2007, 05:09 AM   #35
808Supra
808Supra is on a distinguished road
Default Igniter Coils
I did the same thing hehe, I Was testing some of the components listed and found my ignitions coild put out no voltage and had a resistance of /6-/9 instead of .3. SO i guess those are bad hehe. Anybody have a sugestion where to buy some new ones, or who makes some good ones?
808Supra is offline   Reply With Quote
Old 05-18-2007, 12:54 PM   #36
Z'mnypit
Z'mnypit's Avatar
Some new knock sensors? You may want to try this 1st if thats what your referring to.
http://www.supras.com/06/techcenter/display.php?QID=69
Old 05-18-2007, 10:39 PM   #37
j3pz
if they are all reading the same thing then its unlikely they are bad.
as for the 5psi, it may just be your gauge as the stockers are old and inaccurate. thats one of the things on my todo list also. so be careful shimming, dont wanna run too lean. congrats on getting it started though wish i could do the same
1988 Toyota Supra Turbo runs very rich need help PhillyKorean Non-Generation Specific Questions 0 10-25-2008 03:28 PM
1982 supra runs really rough when cold tylertatum Non-Generation Specific Questions 0 10-04-2005 08:01 PM
