Old 04-18-2007, 08:15 AM   #21
west_side_supra
west_side_supra's Avatar
hmm that seems like alot of work just to set it up for drifting. i agree with everyone else, i dont think its worth the amount of money and work involved. your better off just stickin with the 7mgte or swapping it with a 1jz/2jz, with the 7mgte you will have to keep up on oil, check it before you drift it. the oil tends to slosh around in there. but just get yourself some good coil overs, strut bars, and a cheap set of tires or maby some good drift tires if your willing to spend. and you can drift that supra like there is no tomorrow. hell i drift mine everyday. and its almost completly stock. its not that hard of a car to drift you just goto get the feel for it, learn how heavy it is, have a feel for when you need to give it more gas. just go drift in a big empty parking lot in the middle of no where and do perfect donuts and figure 8's you'll get it down. if you lived closer id teach you how to do it
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 04-18-2007, 08:17 AM   #22
west_side_supra
Originally Posted by dcrusupra
Well, you can only drift with a RWD car. But I'm sure already knew that. The only way I can think of doing it is taking a 3s-gte from an MR-2 and mating a supra transmission to it and making custom tranny and engine mounts, and a custom driveshaft.
and dcrusupra told you how to do it.
fidenza cam gears
Old 04-18-2007, 09:18 AM   #23
Kuban
Its ALOT of work to try and get a transversely mounted engine to sit longitudally. I schemed up a plan to try and do that with the japan exclusive version of the sr20vet, which is a rare version of the sr20det with vvti like timing control for nissan on my 240sx. BUT after alot of research decided that there was waaaay to much fabrication involved and labor for the benifits. Although in ur case there is no physical power gain like there would be in my swap, urs is completely pointless. And even if you wanted to TRY and get this engine to sit transversely in a supra (impossible), it wouldnt be a drift car. I mean yea there are light crx's and light older civics that drift, but there not a 3700lb rwd front heavy car...
Old 04-18-2007, 05:04 PM   #24
west_side_supra
mmm civics and crx's are FWD. they ass drag not drift.
fidenza cam gears
Old 04-18-2007, 06:10 PM   #25
Supra2NR
Supra2NR's Avatar
Maybe a crx since I have seen a rwd crx here b4 and they are pretty light
I don't see why it couldn't drift
Idk about a civic, I guess a rwd conversion isn't too farfetchd
I have seen a 4g63 powered awd civic
That was a crazy setup
But he askd if he had to covert it into a rwd, that makes me wonder if he really knows what he's doing
But here's sum food for thought
Why don't u use the mr2 drivetrain
And create a MR supra
But be sure to find a way to put the engine in front of the rear wheel
Now that would be unique
Old 04-18-2007, 07:37 PM   #26
Kuban
Some eg civics are said to be able to take the awd-train from the element or cr-v i dont remember which one. with modification of coarse.
Old 04-18-2007, 08:09 PM   #27
Supra2NR
Supra2NR's Avatar
They take it from a crv, they steal those a lot cuz of the engine, so they can put it in their civics
Old 04-18-2007, 08:21 PM   #28
Kuban
yea thats it lol.
Old 04-18-2007, 10:27 PM   #29
supradude27_
supradude27_ is on a distinguished road
Default 3sgte
i am finding out how much its going to cost and how much work is involved other wise i will go with a 1jz and i have a 7m and i used to drift mine just fine but i want to do it as a complete drift car so i can compete in drift australia. 7m a the crap of toyota no one makes parts for the 7m enough to copete at national level
supradude27_ is offline   Reply With Quote
Old 04-18-2007, 10:39 PM   #30
Supra2NR
Supra2NR's Avatar
That's the same thing I'm after too, after my enguine gets done I'm saving up money for the rear end, and try compete in amateur drift events,
cuz it will be pretty hard to compete in the drag circuit since its already plagued with 10 second mkiv supras
