Old 10-14-2004, 01:59 PM   #1
the dog
the dog is on a distinguished road
Im having an absolute nightmare trying to repair my supra 1991. The car was overheating and after changing the head gasket, the thermostat and a cooked piston it is still overheating! Im not a mechanic so I dont know but they are saying that the block must be cracked! Which is fantastic after paying out all the money for the HEAD! The only thing not been changed is the Water Pump but they are adamant that is not the problem. Can anyone help please Im at my wits and financial end with it!! :blink:
THANKS
the dog is offline   Reply With Quote
Old 10-14-2004, 11:37 PM   #2
Rollin mk3
Guest
Posts: n/a
Hi, I m sorry to hear that. You know that overheating can be caused by numerous things.
-faulty water pump
-low oil or no oil
-low coolant or old coolant
-bad hoses
-non operating radiator fan
-non working a/c fan (if you use a/c)
The list can go on for a while... My best advise for you is learn about your car, learn about engines, and maybe find a mechanic that you can be friends with!
Old 10-15-2004, 10:14 AM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
hey welcome to the boards
real bummer on ur engine.. know how you feel... been thru a few things like this too
check to make sure that your clutch fan is working properly... while the car is off spin the fan clockwise... if it turns real easy and does say a full revolution without any resistance i suggest you get another cupling for the fan.. also if the fan has a bit of play in it could also mean the cupling is going
what degree thermostat have you got in it?
what went wrong with the piston?
did you get a toyota head gasket?
what was the head gasket torqued to?
when the car was first run was the heater put on full blat till it warmed up?
does the dash gurgle when you start the car?
is your radiator blocked.. have you had it flushed by a radiator company?
did the mechanic take your engine block & head to the reconditioner and get them both prepped for a new head gasket?
it is very important that both surfaces been absolutely clean and also check that your head is not warped
it is very likely that if your engine had gone to a engine shop they would have found a crack in your block so i think it is safe to assume that your mechanic didn't do this (which they should have)
when we rebuild engines we send the head and block to the reconditioner every time without fail
also it is a good idea to replace your water pump at the same time
does the water bubble out the overflow bottle?
how do you know it is overheating? what are the symptoms?
well there's a start for you... let me know all of these and i shall continue
Pics of my build.
Do a diagnostic first!
Old 10-16-2004, 05:27 AM   #4
MA70-1JZ
MA70-1JZ is on a distinguished road
thats pretty much it....
MA70 widebody-1jz conversion with R154, HKS Type S intercooler, Tein HA coilovers, Apexi PowerFC, HKS step one Cams painted in AudiTT Blue
MA70-1JZ is offline   Reply With Quote
Old 10-16-2004, 10:20 AM   #5
Kohkelxon
Kohkelxon is on a distinguished road
I bet supra girl has wheels instead of feet...
Previous car: 1986 Mazda 626 2.0 GTI Sport Saloon
Since 15.3.2005: 1990 Toyota Supra 3.0i Turbo
Kohkelxon is offline   Reply With Quote
Old 10-26-2004, 10:15 PM   #6
GOGS
GOGS is on a distinguished road
hi
by the sounds of it you havent enough grounds to disagree with someone who says they do?
Blaming a cracked block is ok if they can prove it with the head on.
when ive a head off
1 check for where fault was ie gasket visual fault,if not
2 visual fault on block or head face .
3 straight edge all over head/block using feelers ,
4any doubt get engineering firm to press test head.[more likely to be porus than block]
5 any or all of the above can be caused by circulation probs.
6 to say specific block infers hydro carbons in water ,ie exhaust gasses picked up through coolant emmiting hc reading when you put garage gass tester near resevoir.
7 A good test is to break the inside porceline +electrode out of a plug ,weld an airline end onto it +ensure no 1 cyl both valves shut +connect airline.If a cyl/or head prob exists then this will put air into water :blink:
GOGS is offline   Reply With Quote
Old 10-27-2004, 12:52 AM   #7
suprra_girl
7M POWAH! ;)
well i got grounds now LOL
i've been speaking to them over the phone with the mechanics the last week helping them thru the problem... i still maintain it hasn't got a cracked block but nonetheless i have told them to do a block check and a compression check to make sure before we do anything futher... most unfortunately i think the head may have warped again due to the amount they keep overheating it to...
but hopefully i will be hearing from the mechanics soon and we will know for sure
Pics of my build.
Help... my car is overheating suprra_girl MKIII FAQ 40 07-11-2010 06:51 AM
82 Supra overheating suprahusker MKII Supra 2 10-17-2007 01:59 AM
2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor V1P3R MKIII Supra 9 07-17-2007 05:26 AM
car overheating marc MKIII Supra 11 06-30-2006 05:55 AM
Need Help, Overheating Problems MDellboy420 MKIII Supra 9 12-19-2005 06:46 AM
