Old 05-03-2005, 09:08 PM   #1
haze1321
haze1321 is on a distinguished road
Hey everyone today I ran thru a deep puddle and it seems that my intake sucked up some water. As soon as i hit the puddle the car died out and wouldnt start for about 5 min. After finnally starting the car hessiates to go up in rpms. I took off the whole intake and dryed it out. Did I cause any serious damage or will ot dry out and be ok.
haze1321 is offline   Reply With Quote
Old 05-04-2005, 03:46 PM   #2
monkihead
SP58GT
monkihead's Avatar
if you feel the intake sucked in water, the puddle may have been tooo deep. if it started afterwards consider yourself lucky. ususally water will lock up a block after it enters. it sounds like water grounded out an electrical signal on the car.
monique- better off dead
Old 05-18-2005, 01:50 PM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
i would say that you have gotten water in your dizzy or electrical connectors.... how does it idle?
when you first tried cranking it did it... crank stop... sorta like a flat battery or did it just fire nicely, by which i mean did it fire easily or crank stop crank stop
Pics of my build.
Do a diagnostic first!
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 1 05-27-2008 03:23 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 0 05-26-2008 09:27 AM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
