Old 03-25-2007, 03:55 PM   #21
Mark's MKII
Mark's MKII is on a distinguished road
Are you checking the fluid while the car is running. It will show more in it when it's not running. Add some fluid and see if that helps.
Thanks
Mark
Mark's MKII is offline   Reply With Quote
Old 03-26-2007, 03:37 PM   #22
gelwell
gelwell is on a distinguished road
Mark:
Thanks for the suggestion. I finally solved the mystery. It ended up being the screen inside the reserviour. After I had cleaned it as you suggested before, I put it back on the car. It started to boil and bubble over again. It turned out the screen was actually torn and was flapping around clogging up the flow. So I took some hemostats and pulled the screen out completely. Put it back on the car and works great!!
I am again terrorizing the southern california freeways again. This has been a two month maintenance saga. Thanks to you and all the other contributors, I wouldn't have figured it out on my own.
'88 Supra Red, 7mgte motor, auto trans- I know manual is better for this car. Sport top.
gelwell is offline   Reply With Quote
Old 03-26-2007, 08:23 PM   #23
Mark's MKII
Great, I'm glad to hear that your on the road again....with POWERSTEERING
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Power steering pump.. 89 turbo. 2JZEFINI-17 MKIII Supra 4 03-13-2007 03:23 AM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
