Old 03-14-2007, 04:42 PM   #11
ebang
I will check that, thanks....something else, I was filling washer fluid and noticed that it all leaked out, how do I get to the washer resoiver?...I checked the TSRM and could not find it.
1987 N/A Targa 5 speed
no mods as yet
Old 03-14-2007, 07:01 PM   #12
ebang
ok. I went to check the codes on the car as it is idleing way too high still, I could not get the codes, in the little diagnostis box where I have to jump the terminals, is there supposed to be grease on all the contact points?
no mods as yet
Old 03-30-2007, 09:19 PM   #13
ebang
ok...I finally managed to check the codes...this is what happened....two blinks and then a pause, this pattern keeps repeating...what does it mean?
no mods as yet
Old 03-30-2007, 09:46 PM   #14
dannydavi
dannydavi's Avatar
hey i went out and looked at mine, it is located directly below where you fill it up at, prob have to access from below, might even have to remove dust cover or w/e they call that thing, hope this helps.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 03-30-2007, 09:57 PM   #15
dannydavi
dannydavi's Avatar
hey man i located this in the forums that will help you with your diagnosis, i couldnt find blink blink pause though
http://www.toyota-supra.info/forums/...read.php?t=323
i am also having a cold start idle problem, so keep us posted, mine goes to around 12 or 1300 though.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 03-31-2007, 12:46 AM   #16
SideWinderGX
your thinking its '2', maybe its '22'. water temp sensor signal. no idea what that could mean...use that link the guy above me gave you, then go to the TSRM in that post and browse around.
as long as you know its working, it should be fine...however, gauges == really important, so keep looking around.
my car:
Old 03-31-2007, 01:06 AM   #17
dannydavi
dannydavi's Avatar
yeah and if it is 22 then it could be an open or short circuit in water temp. sensor signal, and that link can tell you a lil more, it's a very useful place.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
