Old 03-29-2007, 03:19 AM   #1
Furious1
Furious1 is on a distinguished road
Default Dash lights
Hey,
I'm new to this forum, but I got a question that I didn't see asked b4. I just picked up an 87 n/a on ebay for $700, it's totally sweet. The guy said he'd stored it for two years and when he got it out, it wouldn't run or shift right (A/T) I just changed fluids and never had any problems runningwise with the car. However, the dash lights won't work at all, just the ones that light up the display face when the headlights are on, everything else works great (warning lights etc.) I've checked the obvious (bulbs, fuses) but nothing is working. electronically the only things that have been changed is the TEMS is disconnected due to aftermarket shocks and springs and someone hacked a CD player into it pretty badly. Oh, I don't know if this is in connection with the dash lights or no, but the heater/A/C panel's lights go out when the headlights are switched on and the orange warning light switch is on, but none of the lights bulbs are blown. Any ideas? I'm totally at a loss. . . thanks
Furious1 is offline   Reply With Quote
Old 03-29-2007, 03:30 AM   #2
kwnate
SP58GT
Its common for the dimmer switch to go bad, try to source one for your year or an 86.5. 88 might work but they changed them in 88-89 iirc
Nate
Old 03-29-2007, 04:15 AM   #3
dcrusupra
dcrusupra's Avatar
Damn, you have the same problem i have. Try a new dimmer switch and let me know if it works. I think mine has to do with the switch that you use to turn on the headlights. I'm still not sure tho.
New Rebuild
My CarDomain
Old 03-29-2007, 07:19 PM   #4
Furious1
Thanks, and any thoughts as to where to get a dimmer switch? Just from Toyota? they're kinda juicemasters though. I live in the country so that means all the junk yards are only filled with GM's. . .
Also, I think mine may have to do with the light switch, are they the same on all MKIII's?
Old 03-29-2007, 07:44 PM   #5
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
The difference are in
1986.5-1988
1989(in a year by its self)
1990-1992
Hope this helps.
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
Old 03-30-2007, 05:50 PM   #6
Furious1
Thanks for the info guys. . .I'll let you what works!
supra dash lights wilkoo2 MKIII Supra 1 11-04-2008 04:02 AM
Dash lights and Side marker lights are not working ebang MKIII Supra 0 04-01-2008 12:35 PM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
Dash lights not working! Rommy MKIII Supra 6 05-17-2006 03:55 AM
