Old 02-28-2007, 04:35 AM   #1
Jeff_5_7
Jeff_5_7's Avatar
Jeff_5_7 is on a distinguished road
Default Tranny questions
ok well i just got dont tonite puttin in my clutch i had to buy a new flywheel and a new master cylinder but anyway i got done and now my tranny wont shift int ot 3rd or 4th gear so im pretty much pisssed. Well i was wondering if the tranny out of an mk2 will fit and work cus mines messed up bad thanx .
Supras anrt ricers there Japanese Muscle
1988 supra n/a just finsihed 5 speed swap
goal is 400hp with a turbo motor swap
Jeff_5_7 is offline   Reply With Quote
Old 02-28-2007, 06:40 PM   #2
Jeff_5_7
Jeff_5_7's Avatar
its looks the same and came out of an 82 supra with the 5mge i was wondering if it will work thanx
Old 02-28-2007, 08:19 PM   #3
supraryder
supraryder is on a distinguished road
Default tranny problems
no it wont fit. an 82 supra has a w50 trans and any 86.5 until 92 non-turbo supra has a w58. look it takes a while for the clutch to align the correct way. so you might have to keep turning the car on and off about 50 times. (i have the haynes manual and it was a troubleshoot problem). try it out but an 82 is not the way to go. if you were to get a new tranny get an r-154 from a turbo model. they have way more power and they have lsd.
supraryder is offline   Reply With Quote
Old 03-01-2007, 03:22 PM   #4
Jeff_5_7
Jeff_5_7's Avatar
the transmissions look the same and i hope it will fit but im not sure i need it to cus i have the tranny and i cant afford another one
Old 03-02-2007, 04:15 AM   #5
supraryder
look you can go to any junk yard and find an 87-92 supra. you can grab the tranny and rebuilt it yourself/ it is not as hard as you are making it. here in chicago you can find them anywhere. so just try looking in your local junk yard or try craigslist.com and post a wanted ad there.
2JZ 180sx driftcar (LOTS of questions) Nismo Drifting 11 01-22-2010 03:31 PM
Tranny ? Need Info! SilverBullet05 Non-Generation Specific Questions 0 07-07-2008 09:45 PM
Auto Tranny Issues? jbjorndal MKIII Supra 3 03-14-2008 09:31 AM
