Old 02-08-2007, 04:07 PM   #11
IHateHacks
IHateHacks's Avatar
Ok I had a feeling you did that.
What I do is, take a length of tape (about 2.5 inches long) and split it length wise in half, so you have a 2.5" long 1/4" wide piece instead of 1/2" wide.
Old 02-08-2007, 04:23 PM   #12
redmaro
This is the screw Im talking about.
MK3, Auto, Turbo.
Old 02-08-2007, 06:15 PM   #13
redmaro
Are they suppose to be touching?
MK3, Auto, Turbo.
Old 02-08-2007, 06:28 PM   #14
IHateHacks
IHateHacks's Avatar
Yes, it should be touching it. Since the throttle body is off, just look around while you move the linkage and see what is causing it not to touch the stop screw.
Old 02-09-2007, 02:24 AM   #15
redmaro
Default still no luck
I set the TPS coorrectly and I did what you told me to on the Temp sensor, and its still idleling pretty high. I heard that every time the TPS sensor is adjusted, your suppose to set timing again. The TPS sensor had been moved various times but I never did set it correctly till today. Can timing cause my high idle? I'm out of ideas.
MK3, Auto, Turbo.
Old 02-09-2007, 03:09 AM   #16
IHateHacks
IHateHacks's Avatar
Yes you must set BASE ignition timing after adjusting the TPS. You do know how to do that right? You don't just clip a timing light on and start moving the CPS. You must disable the electronic advance which is very easy.
If that doesn't fix your problem, the only other thing would be a vacuum leak, which are always fun to find.
Old 02-09-2007, 10:08 PM   #17
redmaro
How do you disable the electronic advance?
MK3, Auto, Turbo.
Old 02-10-2007, 07:42 AM   #18
mrnickleye
mrnickleye's Avatar
Default TSRM, sooooo.. easy to use.
http://www.cygnusx1.net/Supra/Librar...ion=IG&Page=20
Actually using the TSRM will save you time !
need help with 7mgte idle problem MAG.net MKIII Supra 4 09-06-2007 06:10 AM
Idle Position Sensor Problem White87Turbo MKIII Supra 4 06-20-2006 05:38 AM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
Idle Problem. Please Help panicos MKIV Supra 18 01-01-2006 06:56 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
