Old 04-25-2005, 09:24 PM   #1
das
das is on a distinguished road
Hi all,
I am sure this question has been asked many times but i cant seem to find a post :-(
I am looking for a new set of aftermarket alloys for my 88 supra, just trying to find out the pcd size and the offset if anyone can help
Thanks
das is offline   Reply With Quote
Old 04-26-2005, 05:40 AM   #2
mk3-drft
mk3-drft is on a distinguished road
A70 (wide body) supras have a offset of 44. factory wheels are 16x7.
A80 supras have a offset of 50 and come from factory in the following configs.
16x8
16x9
17x9
17x9.5
all A80 wheels are a bad idea on a A70 as the offset is different and even the thinnest A80 wheel is still 1" wider than the A70 wheel.
however a 5mm spacer on the front of a A70 will allow you to run A80 16x8 all round.
dont even think about fitting A80 16x9's to any corner of your A70 unless you plan on putting a overlander kit through it.
using a 17" wheel with a closer offset to 44 as possible will allow you to run wider rim than 8" but the best method is to have them fitted to the car and go for a drive including hard turns and full lock steering to make sure of clearances.
enjoy
mk3-drft is offline   Reply With Quote
Old 04-26-2005, 08:30 AM   #3
das
thanks for that drft, as far as i know i have the A70 wide body car but the standard wheels that are already fitted are 16 inch but are already 225mm wide (9 inches) so do i still work with the offset of 44 or should i go for the 50 ?
also i am still trying to find out the pcd setting if anyone knows it,
Thanks again
Old 04-27-2005, 12:24 PM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
we've got 16x8's and 16x9's on our widebody jza70 and she looks all good
Pics of my build.
Do a diagnostic first!
Old 04-28-2005, 01:34 AM   #5
ixcocoyxi
ixcocoyxi is on a distinguished road
what is that A70 (widebody)
or MA70 and stuff.. i hear that all the time and dunno what it is.. :huh:
ps. pics would help too
ixcocoyxi is offline   Reply With Quote
replacing wheel stud Rahnter MKIV Supra 3 12-10-2008 03:57 PM
Supra space saver wheel question aquanuke Non-Generation Specific Questions 0 03-25-2008 10:24 PM
Aftermarket steering wheel RTZ MKIII Supra 10 02-07-2008 08:44 AM
Question concerning disasembling steering wheel Chambers MKIII Supra 2 10-14-2007 03:40 PM
Steering wheel question! lifesnotfair Non-Generation Specific Questions 0 01-14-2006 02:32 AM
