Old 04-20-2005, 09:31 AM   #1
sly380
sly380 is on a distinguished road
just wondering does the 7mgte use a map sensor or just the afm if so where is it cause i must be blind?
also suppra girl are you from oz?
sly380 is offline   Reply With Quote
Old 04-20-2005, 11:24 AM   #2
the 7mgte uses a karman vortex air flow meter.. so yea, big black box on intake can't miss it
i'm from New Zealand another 2 or so hours south of oz
Old 04-20-2005, 09:58 PM   #3
sly380
i take it your talking about the afm where is the vacuum line for the map sensor.
good to see this is a local forum, i thought it was another us one .
im from nsw in oz
Old 04-20-2005, 11:23 PM   #4
the_fallen
the_fallen is on a distinguished road
the 7m-gte uses both afm and map. the afm is the silvery metal piping with a black box on the side of it just behind the air filter case. the afm is what works the actual running of the engine. the map sensor is purely for the working of the digidash boost guage. it does not in any way affect the running of the car.
the_fallen is offline   Reply With Quote
Old 04-21-2005, 12:12 AM   #5
Guest
Guest
Posts: n/a
ok thanks for the info so far but the what what i really want to know is where is the map (manifold air pressure) senor and which vacuum line it uses.
Old 04-21-2005, 01:17 AM   #6
you wouldn't even be able to use the word map in a 7mgte, it just does not exist
there is the turbo pressure sensor located on the left strut tower, same side as your diagnostic box, it is not efi related in any way
so... 7mgte = no map sensor.. anywhere
unless you magically have a turbo A engine, but then then you wouldn't have an afm if you had one of those
Old 04-21-2005, 01:30 AM   #7
sly380
thanks thats what i needed to know
Old 04-21-2005, 05:40 AM   #8
the_fallen
um, suze, what is the turbo pressure sensor?? it detects what pressure is running in the inlet manifold. how does it read that? using a map sensor... so technically, a 7m-gte does use a map sensor, just not for the running of the car
Old 04-21-2005, 06:30 AM   #9
stop confusing the natives!!!! LOL
the 7mgte does not have an efi map sensor :P
TPS Sensor and Auto Trans btwilson86 MKIII Supra 5 02-12-2008 07:31 PM
550 injector & lexus air flow troubles o2 sensor? night-rider MKIII Supra 1 09-03-2007 08:52 AM
O2 sensor? rnoswal MKIII Supra 5 08-02-2006 01:53 AM
