Old 11-25-2006, 04:48 AM   #11
marc
awwe cmon wheres the supra gurus when u need them
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 11-26-2006, 04:00 AM   #12
marc
ok and my over flow bottle keeps getting filled up, and it never empties until i empty it manually into the radiator? whats up w that. and i dont burn coolant.
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 11-26-2006, 05:37 AM   #13
jfunez
jfunez's Avatar
could be a bad radiator cap, or lets hope not ....the dreaded head gasket..
Old 11-26-2006, 10:53 AM   #14
Supra2NR
Supra2NR's Avatar
yup, same here too found oil in my IC pipes, intake pipes, and the 3000 pipe
jus a few more issues with my car
Old 11-28-2006, 05:14 PM   #15
twurbo.oggy
twurbo.oggy's Avatar
twurbo.oggy is on a distinguished road
Originally Posted by marc
yes i know thats my pcv pipe, but where is the valve?
dood, just follow the pipe and you'll find it. its not rocket science
twurbo.oggy is offline   Reply With Quote
Old 11-28-2006, 07:43 PM   #16
Getphazed
Getphazed is on a distinguished road
pull out a plug see if you have oil in there
Getphazed is offline   Reply With Quote
Old 11-28-2006, 07:44 PM   #17
jfunez
jfunez's Avatar
as far I understand, supras dont have pcv valves, instead they have a fixed orifice on the throtle body where that pipe leads to.... that orifice happens to get clogged often..it is recomended to remove the pipe at the throtle body and clean the hole/orifice with carburetor cleaner/trhotle body ceaner and use a small pick or something to open the hole. also make sure the pcv pipe is not clogged up with gum...
hope that helps..
Old 11-29-2006, 03:41 AM   #18
marc
i didnt think there was a pvc valve cause all it did was lead to that little pipe. so would that make it rocket science? lol anyways, would cleaning that thing out make it stop shooting oil into my turbo? and any suggestions about the overflow bottle?
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 11-29-2006, 03:42 AM   #19
jfunez
jfunez's Avatar
wont know until you try it.....
Old 12-04-2006, 01:59 AM   #20
marc
ok. i cleaned the thing out w carb cleaner and q-tips. and, the squeeky thing was my alternator belt, just sprayed it and it stopped. but, the filling of the radiator overflow. not a radiator cap, baught a new one. i thought a bhg makes u lose coolant, not gain it in the over flow bottle.
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
