Old 11-02-2006, 10:39 PM   #1
mad_dicer
mad_dicer is on a distinguished road
Default coolant question
ok here is my problem. last week i replaced my thermostat with a 180 and drilled 2 small holes in it. extra coolant flow. now it runs around 1/4 temp on the gauage but no i have noticed that it is pushing coolant into the over flow. causing my car to get low on coolant and run hot i have to add about 1/2 gallon before i go to work and 1/2 before i come home and i only drive 39 miles one way. i was thinking it was a bad radiator cap but someone said it was a bad head gasket. what do you all think? anybody else ever have this problem? there is no smoke out the exhaust or in the oil either. it also does not run rough or anything else like that. thanks
mad_dicer is offline   Reply With Quote
Old 11-02-2006, 11:22 PM   #2
rnoswal
rnoswal's Avatar
It does sound like the headgasket. I had the same problem and so have many others here. The leak appears between the cylinder and the coolant mostly in the rear of the block. You could try retorqueing the head bolts but the damage has probably already been done.
You may be able to get away with a radiator sealer, but probably not. If you do pull the head, post some pictures of the head, combustion side so we can see how bad the water passages are. Sometimes they get so eaten up that the head has to be replaced, but milling the head and new gaskets along with new head bolts or ARP head bolts and torqueing them down to ARP specs cures the problem for many many years.
Sorry to hear of your problem, but as you will find out, that is by far the number 1 problem with the MK111 Supra. Let us know.
Russ
Old 11-02-2006, 11:37 PM   #3
ZauggIt1
ZauggIt1's Avatar
ZauggIt1 is on a distinguished road
Yeah, it could be the head gasket, but also by drilling those holes in the thermostat, the system cant build up enough pressure. I would just try putting in a 180 and not drilling holes in it. Thats were i would start.
Drive it like you stole it!!!
ZauggIt1 is offline   Reply With Quote
Old 11-02-2006, 11:48 PM   #4
mad_dicer
oh its building up pressure. so much that it blows so much coolant into my over flow that it over flows causing my coolant to go low and even after the car sits for 8+ hours the system still has pressure in it. shoots air and coolant out when i take the cap off
Old 11-03-2006, 03:37 AM   #5
jfunez
jfunez's Avatar
yep...sounds like a blown head gasket...!!
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
coolant on top of piston sevenmgte MKIII Supra 8 05-02-2008 02:34 AM
coolant question D_Train MKIII Supra 1 10-16-2007 08:33 PM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
