Old 10-27-2006, 02:54 AM   #11
volto
volto's Avatar
volto is on a distinguished road
Looks cool, but isnt that just sucking warm air from inside the engine compartment?
volto is offline   Reply With Quote
Old 10-27-2006, 03:17 AM   #12
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
I dunno it runs a lot better than the pvc pipe that was on there.
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
Old 10-27-2006, 04:12 AM   #13
Boostesi
Boostesi's Avatar
Boostesi is on a distinguished road
i got my MAF adapter and filter from pep boys.. i was skeptical about buying the pipes though, comes out well from what i saw in that pic up there
pacesetter cat back
Boostesi is offline   Reply With Quote
Old 10-27-2006, 05:16 PM   #14
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Actually becuase of where it sits the fan hel-ps with cooler air. If you don't want to go through the hassle like I did and put it in the bum-per you can actually use half of the stock air box as a heatshield. Its not an amazing heatshield but it works for the most part from what I understand.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 10-28-2006, 08:42 AM   #15
Supra2NR
Supra2NR's Avatar
i used heat sheilds that pple use to cover thier windows
used two layers of it with plastic in between
and no connection between the two layers
seems to be keeping the hot air out of the intake area
and the tube leading down, i also got a vent for it now
cold air intake marc MKIII Supra 11 10-28-2010 02:57 AM
home make cold air intake ogh MKII Supra 1 08-09-2006 07:38 AM
Cold Air Intake 4 Mk3 Supra2NR Non-Generation Specific Questions 46 07-23-2006 05:34 AM
looking for a new cold air intake lizard_king22 MKIII Supra 5 02-21-2006 11:33 AM
