Old 04-17-2005, 01:42 PM   #11
no no no no no LOL
the solonoid by the strut tower is the turbo pressure sensor which just tells the cluster what boost to display
if you are losing boost or idling rough or puffing out alot of black smoke... "alot"... then check your intercooler pipes as you most likely have a leak
usually the pipe coming of the turbo to the intercooler is a culprit... also check the hose between the 3000 pipe and throttle body... or if you intake is cracked got a hole etc
basically you are looking for a leak between the air flow meter & the throttle body... if a leak is your problem
please describe in more detail "without caps lock on" what your supra is doing
Thanks
Old 05-12-2005, 08:06 PM   #12
88boostr
88boostr is on a distinguished road
hey i replaced the wastegate but the turbo still isnt holding a boost.But when i was replacing the wastegate. i took off the accordian pipe.(the intake pipe that goes to the turbo) and it was ripped.And it is obviously leaking air.could that be my problem?my friend said that wouldnt make my turbo weak like that but you never know.thank you
88boostr is offline   Reply With Quote
Old 05-18-2005, 02:23 PM   #13
the hole in the accordian/intake pipe will cause you to hit fuel cut and there will be lost of power as you will be running rich.... get a new intake pipe and check all of your intercooler pipes for the same thing, cracks, or slipped off etc
Not Holding Boost abhattan MKIII Supra 4 01-10-2007 05:39 PM
