Old 10-24-2006, 04:00 PM   #11
Boostesi
Boostesi's Avatar
Boostesi is on a distinguished road
bump for irratic horn beeping issues lol
pacesetter cat back
Boostesi is offline   Reply With Quote
Old 10-24-2006, 04:27 PM   #12
Isphius
Isphius's Avatar
The clunking is probably related to your metal shavings in your diff. Transmission usually dont clunk, They make other parts clunk. The only real thing you have to look out for with an auto is if its getting hot, or it slips. Otherwise theres not much to break on them
Old 10-24-2006, 04:29 PM   #13
Isphius
Isphius's Avatar
And I have no idea on the horn, I didnt realize the horn had anything to do with the ignition...Never heard of thise before.
Old 10-24-2006, 06:15 PM   #14
Boostesi
Boostesi's Avatar
i guess i could just dissconnect my horn lol. maybe its a bad steering column
pacesetter cat back
Old 10-25-2006, 10:52 PM   #15
f00g00
Default U Joints
A clunk when you put it in drive means that one or more U Joints have gone. They are still there just the little pins have worn out. Be careful though as Ive had my universals changed before and the shop that did the work claims they put it together right and the driveshaft vibrated even after turning it one quarter turn till it was back around again. There are no machine shops here that can balance a driveshaft so Im on my third used one. The first one got screwed when the shop changed the center bearing and one of the yokes.
As for the horn see if its the one thats mounted on the firewall behind the cruise control.Thats the one thats tied into the alarm. I don't beleive the ignition switch is tied into the system except for getting disabled for cranking but you never know, just see which horn it is and disconnect it on the firewall if thats the one honking and you will still have your regular horn. The door locks are the ones that usually go bad for the alarm system.
Old 08-16-2007, 04:27 PM   #16
milkduds45
milkduds45 is on a distinguished road
Default Horn Blowing
Do you have an alarm on it. If so could be your alarm system. Mine has an alarm and when set the horn blows non stop no matter how you open car. Only goes off once key is in ignition and switched on.
milkduds45 is offline   Reply With Quote
Old 08-17-2007, 03:49 AM   #17
ethan12510
ethan12510 is on a distinguished road
Originally Posted by Isphius
The light flashes when the speedo cable broke. Grinding could be a wheel bearing or a bent/dented shock. No idea on the targa seals. The low oil pressure is cause either your pump is starting to go, or your bearings are worn out. Although my n/a was at 0 at times and went up to almost 40 going down the highway, And it ran fine. Check your oil also. And its a good idea just to pull a diagnostic anyways.
does the check engine light come on when ur car is thowing a code? or will it show problems when the light is not on?
ethan12510 is offline   Reply With Quote
Old 08-17-2007, 03:53 AM   #18
supraman121
10-25-2006, 06:52 PM was the last post before you guys brought this dead thread back to life??? almost a year ago??? why lol
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Just got my first supra noob questions help is appreciated vivalajon96 Non-Generation Specific Questions 0 03-29-2008 01:40 AM
noob questions on 89 supra kidthunder650 MKIII Supra 4 03-03-2007 02:35 AM
