Old 10-21-2006, 04:34 PM   #1
stevanom
stevanom is on a distinguished road
Unhappy mysterious starting problem
Hi, mi 1987 MA70 (no turbo) 3.0 6 cillinder has always started in 2 seconds. Even after five years of inactivity it stated in 2 seconds. NOw I have used it intensely, but quietly for a number of months (while waiting for new company car). I had timing belt, spark plugs and orioginal exhaust system replaced at maintenance in a Toyota garage. About five thousnad kilometers later it began to start worse. It gets worse and worse and now I have to try two to three times for several seconds. When it finally runs it turns smoothly, but stutters during about 5 kilometers when driving. After that for the rest of the day it runs and starts like as usual : like clockwork.
oil consumption not even half a liter in 15.000 kilometers
water level steady
temperature steady as ever
kilometers 205.000
Anyone any ideas? I am getting desperate
Thanks already
Steven
stevanom is offline   Reply With Quote
Old 10-23-2006, 07:33 PM   #2
ddmcse
ddmcse's Avatar
Cool
there is a cold start sensor you might look at and a cold start fuel injector
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 10-23-2006, 07:51 PM   #3
stevanom
Hey,
Did not even know he had these, but it does sound logic. Any idea where I can locate these under the hood?
Thanks already
Old 10-23-2006, 07:53 PM   #4
brandonsupra
brandonsupra is on a distinguished road
Yeah I've got the same problem. It takes about 3-4 seconds before it starts and then stutters as if it wants to stall (only SOMETIMES does it do this, usually when it's really cold...oil issues I think). Oil pressure is high until warm, and idles around 1.5k rpm. But then sure enough after 5 minutes when it's warm she calms right down...idles fine again (under 1k about 800), oil pressure drops to a normal level (around 1). Then so long as I don't leave it off for 5 hours or more it will start on a dime, and all levels are exactly where they should be.
brandonsupra is offline   Reply With Quote
Old 10-24-2006, 02:25 AM   #5
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
i have the same problem as well. it takes 2 or 3 tries in the morning to get my car started, but after that it works perfectly.
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 10-24-2006, 02:48 AM   #6
burton51m
burton51m's Avatar
i got my bhg fixed and found all this shit not connected(Power steering, Vacuum hose in intake)..n prolly other stuff that i cant find.
but i have noticed that when i push my remote start button it cranks forever(2-3 seconds) and finally makes a loud clunk or click n gives up. it automatically tries to start it agian and it starts right up
it never did this before so could the cold start sensor be the problem?
Old 11-14-2006, 08:24 PM   #7
stevanom
Smile
Yes! with new spark plugs, new ignition cables and a new delco cap (you know where the ignition cables start from) the car starts like a dream again.
On my Celica convertible I had a similar problem but there it was oxidation of the connecting plug on the cold start sensor.
I am a happy man!
Old 11-14-2006, 08:50 PM   #8
burton51m
burton51m's Avatar
i figured my problem out too....my cam gears had an extra washer in one of them and it was making everything weird.
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
Starting Problem elsleepster MKII Supra 10 01-12-2007 12:13 PM
starting problem Supraman MKIII Supra 8 09-26-2006 09:53 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
i have a starting problem johndawn MKIII Supra 4 02-16-2006 01:16 AM
