Old 10-22-2006, 06:10 AM   #11
boogum7
boogum7 is on a distinguished road
Default shifter
here is pictures of my short shifter mod.
i used that link and it took about 30 minutes to an hour to get it out and put it back in.
ID:	570   Click image for larger version
stock
boogum7 is offline   Reply With Quote
Old 10-22-2006, 09:36 AM   #12
XtreeX
XtreeX is on a distinguished road
Yea im just going to have the timing belt, water pump, bhg and tranny fluid all switched. Hopefully no more loss of coolant at all! And I like that it doenst look to bad.
XtreeX is offline   Reply With Quote
Old 10-22-2006, 09:45 AM   #13
f00g00
Check the hoses ans piping behind the head. The piping is universal and has outlets on both sides so it can go into a lhd or rhd car without having to change to another pipe setup. One side has the heater hose and the other has a plug. A small pinhole leak could drip on the starter area and trickle down the transmission and you might not ever see it till it finally blows. If you look over the whole area and see no discoloration from fluids then its probably OK. You can also squeeze the hose when its cold and see if you can get anything to leak there too.
Old 10-23-2006, 07:13 PM   #14
Cool
i replaced a small plastic ring that goes on the bottom of the shifter
" replaced "
isn't the right word because when i got the shifter out i found that the plastic ring that is supposed to be there wasn't there . i had the play for years and never got around to it
it's not that difficult just a few bolts
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
coolant on top of piston sevenmgte MKIII Supra 8 05-02-2008 02:34 AM
