Old 10-15-2006, 04:42 AM   #11
Isphius
Isphius's Avatar
Putting your car in 1 will not make it any faster off the line than in D. It will just prevent it from shifting. The only time youd need to do this is if your car is modified in some way. The transmission knows what its doing.
Old 10-15-2006, 03:02 PM   #12
Supra2NR
Supra2NR's Avatar
o yes it does,
its bad for the tranny but
it does launch you better than in D
Old 10-15-2006, 08:10 PM   #13
burton51m
burton51m's Avatar
Originally Posted by Isphius
Automatic transmissions work by shifting after your car falls out of its powerband, And it can tell more acuratley than you can, Unless you have a messed up transmission or a motor swap
..well said
no it doesnt...
having it in L (1) is the same thing as first gear in when in D...
except for you shift it when u want when in L, or1 ...which youll probably miss the powerband anyway. so its no better
Old 10-16-2006, 05:43 AM   #14
Isphius
Isphius's Avatar
Yes, lol. 1st gear is 1st gear. shifting it manually is an ego thing.
Old 10-17-2006, 04:33 PM   #15
Supra2NR
Supra2NR's Avatar
no, honestly
i can tell which one throws me back harder
Old 10-17-2006, 09:42 PM   #16
Murd
Because it throws you back harder doesn't necessarily mean you're going faster in a 1/4 mile. Sometimes shifting at a lower RPM than SCREAMING gets you better times. All depends on where the power is.
Old 10-17-2006, 10:29 PM   #17
burton51m
burton51m's Avatar
no, honestly
ego
Old 10-18-2006, 02:51 PM   #18
Isphius
Isphius's Avatar
Thats called the placebo effect. Get a Gtech pro. and yes, supras make all their power before 5500 rpms, so taking it higher than the auto shifts at isnt making you any faster. Unlike my mr2, which has its peak power at 6400 and redlines at 6800, because it is a 1.8L.
Shifting Issues (Automatic) btwilson86 MKIII Supra 4 11-03-2007 07:05 AM
Hard Shifting in Automatic. redmaro MKIII Supra 2 05-18-2007 04:08 AM
Automatic transmission strength pgoughary MKIII Supra 0 12-29-2006 06:48 PM
Is Automatic Turbo worth it ? XKeyLocX MKIII Supra 9 01-27-2006 06:25 AM
Manual Shifting Trouble KingJames224 Non-Generation Specific Questions 3 10-22-2005 09:26 PM
