Old 10-11-2006, 01:01 AM   #1
ZauggIt1
ZauggIt1's Avatar
ZauggIt1 is on a distinguished road
Default Charcoal Canister????
Me and my brother are rebuilding our 87 supra. We both have no clue on what exactly the charcoal canister does for the vehicle. Can someone please explain it for us, and let me know if there is a way to eliminate it for possibly more power. Plus, is blocking off the EGR valve a good idea to?? If so, wont it kick a check engine light on?? Please, all the help is deeply appreciated. thanks guys.
And god bless supra's!!!
Drive it like you stole it!!!
ZauggIt1 is offline   Reply With Quote
Old 10-11-2006, 01:22 AM   #2
j3pz
site for charcoal canister, thanks to mr.nickleye
http://home.sprynet.com/~dale02/evaporat.htm
the egr recirculates exhaust gases to help with emissions. the jdm engines came with block off so it wont hurt the engine, atleast to my knowledge
Old 10-11-2006, 01:28 AM   #3
ZauggIt1
ZauggIt1's Avatar
ok, well that helps me out a little bit, but will i hurt the engine bad if i dont hook it up? or, if i leave it off, is there a way i can just bypass it??
Old 10-11-2006, 03:02 AM   #4
ravenmaster
ravenmaster's Avatar
i don't like linking to these guys but this guy knows his stuff:
http://www.supraforums.com/forum/sho...d.php?t=200192
1988 Toyota Supra Turbo Targa
Old 10-11-2006, 11:24 PM   #5
j3pz
either leave it on, or block it off. just dont leave it open, it will be like an exhaust leak and may cause more problems.
Old 09-06-2007, 07:12 AM   #6
carfanatic89
carfanatic89's Avatar
What if you just put the small vacuum line that come off the canister and goes on the coolant thing straight on one of the intake vacuum ports, would that mess anything up????
Supra Engine Powered Dragster
Old 09-06-2007, 07:39 AM   #7
oowee623
oowee623's Avatar
its been proven that egr doesnt effect performance at all whether you have it on or not. its just an eco-friendly device
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
Old 09-07-2007, 02:16 PM   #8
These posts are getting confusing and messed up. Some of you are talking canister, and some egr.
All the info for both seperate items are on this forum. Check the FAQs section, and also do a search for related threads.
Also...don't just hook vacuum up to the canister, as it will perge the can all the time.
EGR can be blocked off without 'harming' the engine.
Old 06-01-2010, 12:50 AM   #9
wstanek
wstanek's Avatar
steal the engine put in your car! But only if its a 7m! =D
Old 06-01-2010, 09:43 PM   #10
reydio
reydio is on a distinguished road
EGR.....so many discussions on this, as well as other forums. If you have EGR, I suggest keeping it. But if you must remove it and block it....you will need:
1. JDM ECU, USDM ECU is calibrated for use with EGR, ECU will will not function properly without it.
2. Another option, get a stand alone or a piggy back to disable the EGR function of the ECU.
There is a lot of arguments in regards to EGR, it's your car....only you can make that final wise decision.
As for the canister, you can get a smaller type canister from newer cars or get the JDM one which is a lot smaller than the big ones we have.
reydio is offline   Reply With Quote
Charcoal Canister, is it OK? Busted Knuckles MKIII Supra 1 11-10-2008 08:47 AM
Charcoal canister clogged elliotl MKIII Supra 0 08-27-2007 04:21 AM
charcoal canister zuni MKIII Supra 4 06-17-2007 02:03 AM
Charcoal canister removal Kuban MKIII Supra 10 05-18-2007 09:51 AM
