Old 10-10-2006, 02:26 AM   #1
burton51m
burton51m's Avatar
Default Oil Pan gasket
Is it true that you have to pull the motor to change the oil pan gasket?
mine is leaking and thats where it is coming from...
took it in and they said they had to pull the motor to get to the oil pan gasket and that it would be expensive.
just wanted to know if there was another way
Old 10-10-2006, 01:36 PM   #2
supra1985turbo
supra1985turbo is on a distinguished road
Yes there is an other way. break your mounts loose and jack up the front of the engine and put 2 x 4 blocks laying flat between the mounts and the frame and you should be able to pull the pan off and change the gasket. You might have to rotate the crank to get the counter weight in the right position, bbut you should be ablr to get it off. Well thats what I have to My MKII I dont think there is to much difference between the two. MY MKIII does not look different.
1985 celica supra upgrading to street/drag well mainly drag. Have complete HKS T4 turbo kit, electronics and all, Getting head port and polish with HKS 264 cams, and port and polished intake with 6 extra injector bungs. Eagle or crower rods? I just bought a 1990 MA70 n/a .
supra1985turbo is offline   Reply With Quote
Old 10-11-2006, 01:09 AM   #3
j3pz
the crossmember goes right under the oil pan so unless you feel like tearing your suspension apart there isnt another way
Old 10-11-2006, 02:31 AM   #4
burton51m
burton51m's Avatar
alright. thanks guys.
Old 10-12-2006, 11:26 AM   #5
supra1985turbo
Yes your right the cross member does go under the oil pan on the 7m's, but it also goes under the oil pan on the 5m's too. I still can get my pan off on my 5m. By again taking the mounts loose from the frame and jacking the engine up and putting 2 x 4 blocks under the mounts to hold the engine up. I have done this twice to change out rod bearings. yes the oil pan gets snaged that why you just have to work with it to and turn the crank by hand to get the counter weights out of the why. I can do this in about 15 min. I'm a pro at it know.!!!!!!!!!!
Old 10-12-2006, 07:07 PM   #6
burton51m
burton51m's Avatar
ya but i dont have an mkII
hks head gasket suprabahamut MKIII Supra 8 09-01-2007 04:28 AM
head gasket suprabahamut Non-Generation Specific Questions 1 05-04-2007 04:13 AM
gasket help hangsupra MKIII Supra 14 01-28-2007 05:35 PM
