Old 11-16-2006, 02:21 PM   #7
Spudboy
Spudboy's Avatar
Originally Posted by tellfromchico,ca
you can also feed it through with the speedometer cable just have to poke a hole through the boot
The speedo cable hole/boot/gromet was what I was going to suggest. The whole itself is plenty big for more cable. You may be able to squeeze your power cable along side the speedo cable current hole in the boot/gromet. If you can avoid taking that boot/gromet out do it...real pain in the butt to get back in properly. I would also feed your power wire (tape about a 3 inch stiff something to poke through)...feed from the outside (engine bay) in...then contort your body like some yoga dude under the dash and pedals, find it and pull. Good luck.
a few questions about the mkIV supra :D:D bad.boy MKIV Supra 4 09-17-2008 01:27 PM
Buying a Supra, I have some questions. Ungoliant MKIII Supra 7 12-23-2006 05:17 AM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
