Old 10-06-2006, 12:49 AM   #1
mad_dicer
mad_dicer is on a distinguished road
Default replacing instrument cluster
how hard is it to replace the instrument cluster on a 1986.5 NA supra?
i cant seem to find anything in the haynes manual about it.
my speedometer died on the way home
any input is great thanks
mad_dicer is offline   Reply With Quote
Old 10-06-2006, 12:58 AM   #2
tone loc
tone loc's Avatar
to fix im not to sure
to take the old one off is pretty easy just take off the cover that is above the cluster and there is a couple more screws behinde that and then you unplug it and your done. (you might have to take out the center piece and were the fog light,light dimmer,defrogger swichs are to get to a couple screws.)
Old 10-06-2006, 01:05 AM   #3
mad_dicer
i found the whole thing with all the gauges. gotta go pick it up this weekend. was just wandering how hard it would be to pull the old one and put the new one in.
Old 10-06-2006, 01:10 AM   #4
hangsupra
it can be the speed cable from the tranny to the cluster too... or it can be the adapter from tranny to the cable too...
hope this help you little bit tho hehe...
cause that what it happen to me when i on the way home from my friend house and driving fast on the highway... hehe...
Old 10-06-2006, 02:40 AM   #5
mad_dicer
i have already replaced the small cable from tranny to frame. did that first week i had it already checked that its still good. the speedometer ahs been making a squeking noise last 3 days. car has over 250k on it and almost everything is still original.
Old 10-06-2006, 04:46 AM   #6
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
it should be easy to replace. you have to take off the center console piece, the foglight/defog piece. take the top cover off, about 6 screws if theyre all there, take off the screws you see now that are going into the white part of the cluster. unplug all the connector behind the cluster and disconnect the speedo cable. now just pull out. be careful when you work around the speedo cable cus that tip will break easily. i broke mine last week.
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 10-06-2006, 04:58 AM   #7
Isphius
Isphius's Avatar
I think the drive cable or adapter are more at fault than the gauge cluster. The toyota gauges are very reliable, As far as them working correctly.
Old 10-06-2006, 05:11 AM   #8
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
you can use part of this page to help you out
http://supra.co.nz/swap.htm
once you have all the screws from the other items undone you should be able to see all the screws that hold the cluster in
as you start sliding the cluster out you will need to unplug the harness as you go because you won't be able to pull it right out straight away
Pics of my build.
Do a diagnostic first!
Replacing my vavle cover gasket mkiiisupra MKIII Supra 0 11-18-2008 06:50 PM
supra cluster aimtwin Non-Generation Specific Questions 1 09-20-2008 10:40 PM
Need 1993 supra instrument panel part jdbones Non-Generation Specific Questions 0 06-03-2007 11:04 AM
Instument Cluster and Back lights don't turn on! Paulv95123 MKIII Supra 9 06-12-2006 11:21 AM
