Old 10-06-2006, 10:05 PM   #11
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
as i said, it depends on your mods
most hit it between 11 and 13
i myself hit it at 8
and you cannot chip the ecu's but you can buy hks fcd's to wire in to move fuel cut
what did you buy to move fuel cut?
Pics of my build.
Do a diagnostic first!
Old 10-06-2006, 10:06 PM   #12
nelly26
nelly26 is on a distinguished road
i guess the chip in my ecu does not do anything then
nelly26 is offline   Reply With Quote
Old 10-06-2006, 10:08 PM   #13
suprra_girl
7M POWAH! ;)
there is only one type of chip that is available for the 7mgte ecu and that is the (can't remember the damn name) but is made by reg reimer i believe
it's extremely costly to get done and not many do it... it's far easier to do the lexus 550's or hks fcd
so your chip not doing anything... more than likely
you probly had a boost leak and repaired it without even realising
Pics of my build.
Old 10-06-2006, 10:08 PM   #14
nelly26
sorry ill have to find out what chip they used on ecu im not to sure i let jap speciast deal with it has that sort of work i dont touch sorry
Old 10-06-2006, 10:10 PM   #15
suprra_girl
7M POWAH! ;)
all you need to do is drop your ecu down, undo the 4 screws in the top and take a good pic of them
then we'll compare to stock ecu's and see what is different if anything
what mods have you done to your car?
also what year so i can compare to the correct ecu
Pics of my build.
Old 10-06-2006, 10:15 PM   #16
nelly26
not much had head gasket done with stainless steel one and had hybrid turbo fitted . i am still looking for the right body kit having problems finding the right kit . i have bbs wheels and straight throught exhaust. im steel looking the right stuff in uk its hard to get right stuff
Old 10-06-2006, 10:15 PM   #17
suprra_girl
7M POWAH! ;)
one more thing
could you describe what fuel cut felt like to you?
did it ever throw a check engine light or just misfire?
curious
Pics of my build.
Old 10-06-2006, 10:20 PM   #18
suprra_girl
7M POWAH! ;)
gomez: are you 5sp or auto?
does it do in a specific gear?
how much traction loss is there
only in wet? or both?
Pics of my build.
Old 10-06-2006, 10:21 PM   #19
nelly26
i would accelerate to 125 mph and it would cut out after a few seconds it would start running with a bit of missing for a few seconds and then no problems i was told by mechanic it was fuel cut off he then chipped it that is what told me it cost me about 200 pound it could hks i have had a look invoice sorry he told me it was chipped git
Old 10-06-2006, 10:24 PM   #20
nelly26
ecu did flash but i left to mechanic to sort out
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
