Old 09-25-2006, 11:54 PM   #1
marc
Default yet another problem
ok well 1st i installed my new starter and the car has been starting fine. but, today i went to start it did the wum wum wum wum then finally started. as i was driving my lights seemed very dim and my radio could not keep a connection and kept shuttign off, almost liek my battery was dead. then i parked it, tried to start it again, and it wont start wont even crank. im thinking i need a new altenator? any1 agree? or disagree? does any1 know if the voltage regulators come built into the alernators with these supras?
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 09-26-2006, 12:19 AM   #2
sd88supra
sd88supra is on a distinguished road
new alternator for sure. easy to replace.
sd88supra is offline   Reply With Quote
Old 09-26-2006, 02:51 AM   #3
marc
does the voltage regulator come with the alternator, liek is it built in?
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 09-26-2006, 09:58 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
yep regulator is built in
check water levels in battery
check with multimeter while car is running to see if your alternator is charging
Pics of my build.
Do a diagnostic first!
Old 09-26-2006, 06:46 PM   #5
supra1985turbo
supra1985turbo is on a distinguished road
You know personaly I would take the battery to autozone or oriellys to have the battery checked, if you check the battery and alternator while the car is running you can come across with a messed up situation, your alt could be good but reading bad because your bat is so far gone that it is pulling so much from the alt. that the internal reg will not keep up. Trust me found out the hard way. But got my money back. It could also be your bat terms.
supra1985turbo is offline   Reply With Quote
Old 09-26-2006, 11:29 PM   #6
marc
yep, was a bad battery. replaced it today and its fine now
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 09-26-2006, 11:52 PM   #7
suprra_girl
7M POWAH! ;)
woohoo at least it wasn't too painful
Pics of my build.
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
