Old 09-15-2006, 05:40 PM   #1
ghetto
ghetto is on a distinguished road
Default No Rpm's
So I just got an 88 7MGTE put in another vehicle, when I pulled it it ran great. Now it starts up fine but it won't rev up high enough to get into the turbo. It cuts out, and black really rich smoke comes out the exhaust. I have a 3 " exhaust. Oh and another wierd thing. When I first got it done it ran like this and then all of the sudden started running perfect. I rolled it, and now it runs like this again.
ghetto is offline   Reply With Quote
Old 09-15-2006, 05:53 PM   #2
ghetto
Default one more thing
I pulled codes and it gave it me knock sensor, starter signal open or short, and I dont remember the third one but, it didnt seem like it was something that had enough power to do that.
Any ideas, maybe the timing not advancing? I dont know, any thoughts would be nice.
Old 09-15-2006, 05:53 PM   #3
Isphius
Isphius's Avatar
Search for "boost leak". You have one. There is A LOT of threads on it.
Old 09-15-2006, 06:03 PM   #4
ghetto
I know I have a boost leak. I ordered a new hose. Would that cause it to cut out so violently?
Old 09-15-2006, 09:52 PM   #5
justin1642
justin1642's Avatar
justin1642 is on a distinguished road
yeah it depends on what hose it is that blew. i blew off the hose to the bottom of the turbo on mine and i couldn't go. the car couldn't go more than 5mph. i thought i screwed the car up but then i saw the hose and fixed it. and some hoses will make the car not work to full potential and cut some boost. so boost makes a big difference on how it runs.
justin1642 is offline   Reply With Quote
Old 09-16-2006, 08:28 AM   #6
Isphius
Isphius's Avatar
Well when the motor is under vaccum, its trying to squish the tubes, so it would seal the crack. Then once the pressure comes on, the air leaks out, and then your ecu thinks the motor is using the air, and dumps the ammount of fuel for air thats going in, but its not getting into your motor (the black smoke is the extra fuel).
lex 550s boggin out near 3000 rpms? night-rider MKIII Supra 10 11-07-2008 01:03 AM
Please help...93 N/A high RPMs uberbg MKIV Supra 5 11-12-2007 04:04 AM
1986.5 Idling at high RPMS Sasukevh MKIII Supra 2 06-14-2007 04:56 AM
Engine seems powerless until higher RPMs Ahmad88 Non-Generation Specific Questions 8 06-22-2006 01:58 PM
Sputter @ high rpms with pedal all down! MKIIISupraTurbo Non-Generation Specific Questions 2 11-11-2005 01:47 AM
