Old 09-14-2006, 04:13 PM   #1
idoke
idoke is on a distinguished road
Unhappy I need help! My supra idles rough at cold starts...=(
1991 Toyota supra turbo
5 speed
One morning, my supra started idling funny. I remember turning it on. The temp gauge shows Cold and as I was driving it. At first, it runs good until it started warming up. As soon as I came to a stop, the engine started idling funny and at times, it will die (Only if I was to put it in neutral) When in gear, it runs but kind of wierd. I shut the car down for about 3-5 minutes. After that, I started it up and took it for a test run. Amazingly, it ran fine again. It does this every morning or every COLD start. ???? What's going on? I really want to fix this problem and I'm calling out to all Supra owners and fans to really help me. Please help me for I am a supra fan in need. Thankyou.
idoke is offline   Reply With Quote
Old 09-14-2006, 05:55 PM   #2
sd88supra
looks like a maladjusted or bad throttle position sensor. check your error codes, you'll probably get a 41 or 51. 41 youll have to adjust it using a multimeter, 51 youll need a new one. very easy job to do. the TPS can make the world a difference. also make sure you dont have any air leaks.
Old 09-15-2006, 02:56 PM   #3
idoke
Thanks. I'll give it a shot to see what happens.
Old 09-15-2006, 05:56 PM   #4
Isphius
Isphius's Avatar
Yes, check yout tps. It could also be something like bad plugs too. Mine had a problem like that, And all i did was replace the stock idle adjustment with a home depot bolt with a nut on each end. The idle screw was moving around nad making my car not want to run.
Old 09-18-2006, 04:07 PM   #5
idoke
Where is the stock idle adjustment?
Old 09-18-2006, 04:11 PM   #6
Isphius
Isphius's Avatar
Have your friend move the gas pedal, look at the throttle body. The part that moves, there is a crappy screw in there with a slot cut into it for a screw driver. Take it out, Goto home depot, Get a stainless steel one out of the hardware section, and get a few nuts and lock washers. It will never move again lol. Make sure you get the bolt with the hex head too, not the screw driver kind.
Old 09-19-2006, 02:55 PM   #7
idoke
I'm trying that right now! I'll let you know by tomorrow! Thanks!
SUPRA LSDs AND COLD AIR INTAKEs QUESTION C0o0n Non-Generation Specific Questions 2 08-10-2008 02:33 AM
rough cold start sd88supra MKIII Supra 2 11-18-2006 09:15 PM
supra running rough finn MKIII Supra 0 09-25-2006 07:10 PM
1982 supra runs really rough when cold tylertatum Non-Generation Specific Questions 0 10-04-2005 08:01 PM
