Old 08-30-2006, 07:09 PM   #1
Burn N' Up
Burn N' Up's Avatar
Default changing out ring gear
anyone ever heard of changing out just the ring gear in a differential? Do you have to change the two half axle drive gears too or are they basically interchangable?
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
Changing LSD oil. redmaro MKIII Supra 8 04-28-2007 11:13 PM
changing gear oil Levi1717 MKIII Supra 10 01-08-2007 03:34 AM
quick question blacksheep Non-Generation Specific Questions 10 01-01-2007 08:19 PM
lower timing gear quamme Non-Generation Specific Questions 0 12-12-2006 12:41 AM
Second Gear Sound dcrusupra MKIII Supra 9 12-24-2005 08:05 AM
