Old 07-19-2006, 02:47 PM   #1
Supraman
Supraman is on a distinguished road
Default air fuel gauge
I'm trying to install a air fuel mixture gauge in my 91 Supra Turbo. Does anyone know where to connect the gauge for the O2 sensor. Ive read that you can connect it to the diagonstic box but I do not know where precisely. I had hoped to connect it under the dash near the cpu. Anyone have any good suggestions. Thanks
Supraman is offline   Reply With Quote
Old 07-19-2006, 05:44 PM   #2
Supra2NR
Supra2NR's Avatar
which type did you buy,
i saw one that only needed to be connected to the o2 sensor and your good to go
Old 07-19-2006, 05:58 PM   #3
Supraman
Its a summit racing gauge it does say to connect to the o2 sensor. But I was hoping for something under the dash to splice into rather than under the hood . But I might not have a choice.
Old 07-20-2006, 12:48 PM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
you can connect to vf in the diag box (02 feed)
edit: vf should also be at the ecu
Pics of my build.
Do a diagnostic first!
Old 07-20-2006, 01:34 PM   #5
Supraman
Can you tell me if it would be marked at the ecu. Or maybe a color of the wire. Ive looked thru my chiltons and cant find it in the diagram.
Old 07-20-2006, 01:42 PM   #6
suprra_girl
7M POWAH! ;)
looks like it's green w/ red stripe the VF wire
For reference the original toyota 1990 TSRM is located at http://cygnusx1.net/supra/library/TSRM/
don't bother with the chiltons lol
Pics of my build.
Old 07-20-2006, 06:20 PM   #7
Supraman
I dont know where you find this stuff but thanks for the help.
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Air fuel gauge west_side_supra MKIII Supra 5 06-09-2007 06:39 AM
