Old 06-21-2006, 04:25 PM   #21
theWeezL
theWeezL's Avatar
I flushed and changed my coolant not too long ago, and after I filled everything up (including the overflow bottle) my "birdcage" light was still on. It turns out that when I was shooting a high pressure stream of water in the bottle to clean out all the goopies, I cause the float on the sensor to get stuck. I took the bottle back out, dumped it out and turned the whole thing over and the float didnt move. I gently reached inside with a screwdriver and free'd it up. That cured that issue.
If your check brake light warning is coming on and going off it sounds to me like you may have a bad connection somewhere. I have seen bulbs get all corroded and make poor contact in their sockets lots of times. I would start there. Take each of the bulbs out, clean them (one of those green kitchen scrubbers works great for this) and put them back in.
As for your check engine light being on, it means that your computer has senced something is wrong or was wrong in at least one area of operation of the engine/trans. It could be simple or it could be real trouble. you wont knonw until you "retrieve" the code from the memory.
Go to this page to understand more about checking your codes: http://www.toyota-supra.info/forums/...read.php?t=323
____________
Old 06-21-2006, 04:31 PM   #22
damdog05
damdog05's Avatar
there might also be another culprit for the brake light. make sure there is enough fluid in your brake master cylinder.
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Old 06-21-2006, 06:06 PM   #23
IHateHacks
IHateHacks's Avatar
"As for your check engine light being on, it means that your computer has senced something is wrong or was wrong in at least one area of operation of the engine/trans."
There are no check engine codes for 87-92 supra that refer to the automatic trans. There is a separate computer for ECT (electronic controled trans) codes that are accessible through the Super Monitor or flashing it out the O/D off light.
Old 06-21-2006, 06:16 PM   #24
theWeezL
theWeezL's Avatar
I was giving a generic "check engine light" responce...
but thanks for clarifying
____________
Old 06-21-2006, 09:51 PM   #25
Ahmad88
Ahmad88 is on a distinguished road
lol thanks for the help guys, but how do i take out brake lights? can you gimme step by step instructions or a link? thanks
Rollin in a 98, flippin 94's
Ahmad88 is offline   Reply With Quote
Old 06-21-2006, 11:37 PM   #26
damdog05
damdog05's Avatar
the actual lights themselves? in your trunk there are two access panels right behind the lights. go in through there
My cars:
Old 06-22-2006, 01:23 AM   #27
theWeezL
theWeezL's Avatar
^^ what he said...once you get behind those panels you will find a white plastic panel that holds all the lights. You unplug that and pop it out of the tail light housing to get at your bulbs.
____________
Old 06-22-2006, 02:19 PM   #28
Ahmad88
thx i'll do it this weekend and let you guys know.
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Engine light and warning light on. Chomper MKIV Supra 11 07-18-2008 11:44 AM
Warning light question scruffboy Non-Generation Specific Questions 4 06-11-2007 11:16 PM
Warning light question thetrueaint MKIII Supra 4 08-29-2006 06:07 AM
