Old 06-14-2006, 02:32 PM   #1
IHateHacks
IHateHacks's Avatar
Default Coolant temperature?
Could someone with an aftermarket water temp gauge and a good motor tell me what a 7MGTE runs at?
With a NAPA 180 F degree thermostat im seeing 185-200 F degrees with 200 under full boost climbing a mountain on the highway, and 185-190 around town, stop and go.
I bought a Toyota 88 C degree thermostat (190.4 F degrees) that weighs 3 times as much as the crappy one im using at the moment, but seeing its a higher temp im hesistant to use it.
So could anyone with an accurate aftermarket water temp gauge and a known degree thermostat please tell me what you run?
Old 06-15-2006, 01:11 AM   #2
ddmcse
ddmcse's Avatar
Arrow
i have a toyota 160 thermostat and the numbers are about the same except i don't get to 200
and on a night like tonight here in ct , it will hang around 170 off the highway on back roads.
i think it's an autometer gauge
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 06-15-2006, 12:40 PM   #3
IHateHacks
IHateHacks's Avatar
Hey thanks for the response. So you see 10 degrees above your thermostat rating just like I do around town. And its not quite 200, the gauge reads 190 then 230 with a line 50% inbetween them being 210. The needle barely makes it 25% of the way from 190 to 230, with 25% being 200 degrees. So its probably 197 or 198 but pretty goddamn close to 200. Thats under 7.7psi climbing a huge ass hill about 1 mile long.
1 more thing too, I have power to my gauge with the key just to ACC so I can monitor temp with the ignition totally off. Now, as soon as I turn the car off when warmed up, the needle always moves down about 5 degrees from where it was with the ignition on and the engine running, meaning because of all the electrical loads the resistance is a little higher when running, resulting in an inaccurate reading by 5 degrees.
I dont know maybe Im thinking to hard, I just want to know if its normal.
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
Coolant Temperature Sensor scruffboy Non-Generation Specific Questions 1 12-05-2006 02:40 PM
