Old 05-26-2006, 08:34 PM   #1
G-string
G-string's Avatar
G-string is on a distinguished road
Default quick questions
number one
Is wd-40 safe to use to clean my car parts ?
number 2
What should i tighten the head bolts to i have them at 50 like my aynes book says but with all the head gasket shiot that these cars have what would be the best torque ?
hopefully some one can answer soon thanks
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Old 05-26-2006, 09:06 PM   #2
burton51m
burton51m's Avatar
wd-40 is safe. my friend cleaned his engine with that but got it on his belts. it wasnt good. keep away from the belts and things if you clean your engine.
Old 05-26-2006, 09:10 PM   #3
rnoswal
rnoswal's Avatar
Well WD40 isn't really a cleaner but it will clean some stuff. It isn't really a good lubricant either, but it will do that a bit too. WD40 is best used for wetting the cylinder walls when installing pistons. Use a brake cleaner if you are trying to get some really gooey stuff off and it won't leave a residue or a good parts washer is a nice thing to have.
Most of the people on here are torqueing the stock head bolts to around 72 to 75 lbs, but again it depends on what you are using for a lube on the threads. My ARP studs call for 80 if using their lube but they say 130 if you use a 30 wt oil. That makes no sense to me so I will use their lube. I can't imagine 30wt oil being that slick to require that much torque, but that is what they say.
I usually go up to about 40 lbs first then up by 15lbs each time then a final check to the correct torque.
Hope this helps some.
Russ
Old 05-27-2006, 06:29 AM   #4
Wink Wd40 ?
Yep ^^^ 72 lb ft of torque is the general consenses, using motor oil on the threads of factory bolts. $40 from Toyota. Since you already have them at 50, go on up to 72 in 15 lb steps.
WD40 was developed for use in the 'space program'. (hey, 11 years there, I got some retirement coming, when I get old and crotchety, hee hee).
It is a metal protectant to keep moisture off. It works pretty good as a rust penetrant, and very light oil applications. It displaces water, but leaves residue (film).
Simply Green, full strength, works pretty good to de-grease under hood. Spray it on, let it sit for 20 min., then wash it off with 'Brake Clean'.
Old 05-29-2006, 04:01 AM   #5
Dejvid1785
Dejvid1785 is on a distinguished road
I used ARP head studs and torqued the head down to 80lbs. Its been almost 5,000 miles since i did it. Do i need to re torque the head even with the arp setup?
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 05-29-2006, 06:09 AM   #6
not from personal experience but on another forum a member mentioned that by not retorquing his studs he was experience leaks under high boost
it wouldn't hurt i imagine, just crack em one at a time and retorque em up
Questions before buying a Supra proximityburn MKIV Supra 5 08-15-2008 02:09 AM
Questions about the oem fuel system Magical Trevor MKIV FAQ 7 08-19-2007 04:40 PM
Newb with newb questions 1jzToyota MKIII Supra 4 11-07-2006 01:24 PM
