Old 05-31-2006, 10:56 AM   #21
ddmcse
ddmcse's Avatar
Cool
here is a basic "how to "
http://www.geocities.com/MotorCity/S.../1636/bhg.html
you shouldn't have any problems just keep track of every part
plan on a few hundred bucks to have the head looked at to be sure it's square and not warped
on the very rear of the head there are little tiny plastic dots they are indicators of severe heat
severe heat would cause warp
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 06-01-2006, 02:46 AM   #22
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
Thanks guys you have been a big help. I cant get the head bolts loose and I am afraid I will strip out the head of the bolts. Is there a trick? Do all the lines have names? lol. They seem to be specific angles and everything.
h8z2luze is offline   Reply With Quote
Old 06-01-2006, 04:14 AM   #23
dcrusupra
dcrusupra's Avatar
It takes a lot of muscle to get them out. You wont strip them. Just use the 10mm hex head and make sure its in there good and start loosening. You'll be tired by the 5th or 6th one. By the 3rd one I was dripping sweat. But thats only because i didnt have a breaker bar. And use craftsman tools to get them out so if u mess it up u can take it back and get another one. I broke the ratcheting mechanism on one trying to get them off.
New Rebuild
My CarDomain
Old 06-01-2006, 04:25 AM   #24
h8z2luze
h8z2luze's Avatar
Ok the hex bolts on the top of the head in the middle right? I only saw like 4. This car is confusing the crap out of me.
Old 06-01-2006, 04:40 AM   #25
dcrusupra
dcrusupra's Avatar
They are all over the place. Lol. Just run a flashlight by the cams on the inside part of both cams. You'll need to rotate the cams to get to 1 on each side. Just take an adjustable wrench and look for the part that is squared off a little and turn it a bit.
New Rebuild
My CarDomain
Old 06-01-2006, 04:55 AM   #26
h8z2luze
h8z2luze's Avatar
Ok im confused. This is what im talking about.
Old 06-01-2006, 05:09 AM   #27
dcrusupra
dcrusupra's Avatar
Yes those are the head bolts im talking about. And no the big hex ones arent head bolts.
New Rebuild
My CarDomain
Old 06-01-2006, 05:51 AM   #28
f00g00
Default Can't open link?
Install adobe acrobat reader on your puter and then you can open the earlier link.
Old 06-01-2006, 01:12 PM   #29
rnoswal
rnoswal's Avatar
There are 14 head bolts with the 10mm hex holes. The larger aluminum ones, (4) hold the plate for the spark plug boots, the others in the head go into the water jackets, leave them alone. You can take off the ones that hold the spark plug boots, I think they are 12 mm, but it isn't necessary to remove them, but cleaning under them is easier. Just get a good 1/2 in breaker bar, about a 6 inch 1/2" extension and the I use hardened reducer to 3/8" and then the 10mm allen socket. They are on at least 55 to 60 lbs of torque. And like was mentioned earlier, make sure the inside of the head bolt is clean so you can fit the allen socket all the way in the bolt.
Let us know how it goes.
Russ
Old 06-01-2006, 03:55 PM   #30
h8z2luze
h8z2luze's Avatar
No wonder I couldnt get them off. Anyway I couldnt tell that the head bolts were allen heads I was trying to fit a socket down in there. haha. Wondering why it wouldnt fit. Talking about torque one time i helped my friend put some race heads on his 71 Dart and they had to be torqued to 180 pounds. That was fun lol.
Blown Head Gasket Symptoms! Dejvid1785 MKIII FAQ 76 04-24-2011 07:59 PM
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
Update: Blown Head Gasket Snake Oil - 8 months later unkymurch Non-Generation Specific Questions 3 12-17-2008 09:35 PM
