Old 05-21-2006, 01:04 AM   #1
Metalshredder_25
Metalshredder_25 is on a distinguished road
Default Interchangable parts?
Hello everyone I have a 88 toyota surpa turbo and as most of you already know our parts aren't cheap and there isn't any supra's in any local scrap yards so I was wondering if anybody had a list of interchangable parts from other toyota's?.Just for instance I need a fan shroud and a new radiator and some misc hoses.
Metalshredder_25 is offline   Reply With Quote
Old 05-21-2006, 04:19 PM   #2
Burn N' Up
Burn N' Up's Avatar
The supra is a rocket ship, especially the turbo, it has the highest grade technology available at the time crammed into a car that is not very big. Needless to say alot of parts were designed for that car and that car only.
Old 05-21-2006, 04:29 PM   #3
joel w
joel w's Avatar
Also, Look for cressidas, They had 7M motors.
As far as i know its just the cressy?
Old 05-21-2006, 09:14 PM   #4
Metalshredder_25
So not even a camry from the same year would have used the same rad or other parts?
Sorry for all the stupid questions but I'm trying to fix up my baby on a tight budget.
Old 05-22-2006, 06:36 AM   #5
f00g00
Default Crown
I got my radiator from an 87 Toyota crown which also had the 7M-GE but I don't think the car was available in the USA.
Old 05-22-2006, 02:40 PM   #6
KNYFE
KNYFE's Avatar
KNYFE is on a distinguished road
You don't have to have a fan shroud.... There is a thread below that goes more in depth on that topic.
http://www.cardomain.com/id/FastnLowI30
Supra, I30 and A8 are above...
KNYFE is offline   Reply With Quote
Old 05-23-2006, 02:11 PM   #7
theWeezL
theWeezL's Avatar
Well, it really all depends on what you mean by usable...how much modification are you willing to do or capable of doing? For a Radiator its all about dimensions and location of inlet/outlet. when it comes time to mount it swapping your mount off an old radiator or fabricating one is always an option.
I once used a radiator out of an old fiat in my 73 Celica. I had to use my brackets, but they could be unsoldered with a propane torch...so like I said, take careful measurements, then go hunting.
As parts become harder to get (I know all about it having had 4 1st gen Celicas) you need to learn to use whats available, or stockpile when you do find a parts car. I found an exact duplicate of my supra down to the body color and interior for $500. Im in the process of stripping every single usable part and putting em in boxes in my attic for just such an occasion.
Old 05-23-2006, 04:51 PM   #8
joel w
joel w's Avatar
I disagree..The fan shroud is absolutely needed to make your thermal fan clutch work properly.. With out it, it will not engage/lock the fan clutch to pull the air through the radiator.
It may not be needed when driving, but sitting in traffic on a hot day may cause you to over heat.. These cars do not like it when they over heat...
87 MkIII vs 89MkIII -- parts interchange willblock MKIII Supra 5 07-24-2016 06:27 PM
