Old 05-10-2006, 01:56 AM   #1
White87Turbo
White87Turbo is on a distinguished road
Default Stupid Light
So I have recently rebuilt an 87 Turbo Targa Top, 5 speed with a 7m-gte. I have a light up on the dash that looks like a temple sort of thing to the left of the gauges. Does anyone know what this is or how to get rid of it. I also cant get the back lights to turn on and wonder if there is a switch or something i have to get so i can see how fast im driving at night. Sorry, Im still pretty ignorant to how this thing works even though i rebuilt the engine and a major part of the interior.
Thanks for any advice you have.
White87Turbo is offline   Reply With Quote
Old 05-10-2006, 04:35 AM   #2
dcrusupra
dcrusupra's Avatar
Coolant light. Theres a little dimmer switch under the panel on the left side of the steering wheel, thats either turned down or broken and you need a new one.
New Rebuild
My CarDomain
Old 05-10-2006, 05:18 AM   #3
Isphius
Isphius's Avatar
add some water to your overflow bottle. And replace the dimmer switch in your dashboard. The light on is usually a signal that your leaking coolant thou
Old 05-10-2006, 12:41 PM   #4
White87Turbo
There is a leak for sure in it. So Im going to find that tonight and try and get it fixed.
Old 05-11-2006, 02:00 AM   #5
Isphius
Isphius's Avatar
Aside from the coolant leaking leaking, it might also be the HG. That light is sometimes called a BHG light
Old 12-09-2006, 01:53 AM   #6
GTE89
GTE89's Avatar
GTE89 is on a distinguished road
Default BHG Light
I have a BHG light on too! Haven't found any leaks yet though. Its funny because I thought I heard a trickling of water the other day and now. The dreaded waterfall sound from the dash too!
GTE89 is offline   Reply With Quote
Old 12-09-2006, 05:17 AM   #7
Isphius
Isphius's Avatar
8 month revival!! lol. Yeah its probably your HG if there is no visible leaks.
Old 12-09-2006, 05:49 AM   #8
supraman121
Mine leaks anti freeze so i get that light every once and a while and then the water sound after i filled up my antifreeze to much it spit it out lol
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
Warning light question thetrueaint MKIII Supra 4 08-29-2006 06:07 AM
