Old 04-21-2006, 02:31 AM   #1
sd88supra
sd88supra is on a distinguished road
Question air opening
where can air leak through into the car when driving at high speeds? my 87 NA gets air inside when driving fast and the windows are up all the way. i cant feel air through the top of the window, so i know theres no leaks there. but, i can hear the air flowing in close to the door mirrors and side vents. where should i look for a leak? also, would these seals be available aftermarket?
sd88supra is offline   Reply With Quote
Old 04-21-2006, 04:35 AM   #2
dcrusupra
dcrusupra's Avatar
Its not a seal. Its the thing that the side mirror is bolted onto. On the top of the triangle it usually separates letting air thru. It could also make the window sag a little bit. It's a dealership item.
New Rebuild
My CarDomain
Old 04-21-2006, 01:06 PM   #3
rnoswal
rnoswal's Avatar
That is the area that leaks air. You could try a thin piece of weather stripping to try and seal it. I did that on my targa top and no more water leaks, so it might work in the mirror area too.
Russ
Grand Opening 88suprafast1 Shops & Part Reviews 1 11-16-2007 06:41 AM
Gas cap cover not opening! Chambers MKIII Supra 5 07-25-2007 10:15 PM
gas hatch not opening sd88supra MKIII Supra 4 10-14-2006 04:12 AM
opening to dash? sd88supra MKIII Supra 6 09-28-2006 12:25 AM
trunk not opening from inside burton51m MKIII Supra 2 05-13-2006 05:42 AM
