Old 04-10-2006, 02:40 AM   #1
lilsmitty
lilsmitty is on a distinguished road
Default Need a little help wit my 87 supra n/a
OK First whats that little light next to the light that tells you when ur doors r open..and second what do you think it means when i shift into second and try to cherp um my clutch gets stuck to the floor and i have to pull it out but after i pulll it out its fine?
lilsmitty is offline   Reply With Quote
Old 04-10-2006, 04:05 AM   #2
dcrusupra
dcrusupra's Avatar
Not sure off the top of my head what the light is. What does it look like? And the theres probably air in the lines for the clutch. Bleed it and see what happens.
New Rebuild
My CarDomain
Old 04-11-2006, 03:16 AM   #3
lilsmitty
Yea but it only does it in second. And second seems weird sometimes like its hard to get into it.
Old 04-13-2006, 01:00 AM   #4
Burn N' Up
Burn N' Up's Avatar
bleed the air in the clutch, the clutch doesn't know what gear your going into, it just knows clutching or flying. Which little light, what does it look like?
