Old 02-23-2005, 12:24 AM   #1
Supra Guestobrut89
Guest
Posts: n/a
[FONT=Imp[COLOR=orange] hey im new to this sight but i was wondering if anyone could help me i have an 86.5 supra that i have built from the ground up i put an 89 turbo motor in it i cant get the car to start yet but thats not the problem when i tried to start it i cranked it for like 15 minuts and all of a sudden oil started pouring out the exaust side of the turbo i read the manual and it said something about it not getting any water will cause the oil lines to not be able to drain back down to the oil pan i didn't put water in yet i didn't think that i would need it just to see if the car would crank im not sure what to do please help
Old 02-27-2005, 08:57 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
water is actually not required to lube anything in the engine or make the engine do certain things....
water is only required once the engine reaches a certain temperature so that it "stays" at that temperature
so you can safely run an engine for a min or so with no water and it wont generally have ill effect
do you know if the oil was actually coming out of the motor or out of the exhaust of the turbo?
take off the turbo and see if there is oil in the exhaust manifold... if there is i would say your rings are gone... if there is no oil before the turbo but is after get your turbo rebuilt and you should be happy
why won't your car start?
Pics of my build.
Do a diagnostic first!
Old 02-27-2005, 05:00 PM   #3
Supra Guestobrut89
Guest
Posts: n/a
well you see im building this car from the ground up and i did a turbo swap i thing the gass is no good that was in the car that or its just out of time it was hitting so its wanting to start
Old 02-28-2005, 12:13 AM   #4
Supra GuestOBRUT89
Guest
Posts: n/a
WELL I FIXED THE OIL PROBLEM THE GASKETS FOR THE OIL RETURN LINE DID NOT HAVE THE HOLE CUT IN TO IT SO THAT THE OIL COULD RETURN TO THE OIL PAN
Old 03-14-2005, 08:05 AM   #5
suprra_girl
7M POWAH! ;)
mint
i had that problem a while back as well... leant to tighten and replace gaskets once i did that the first time hehe
good luck with the car
Pics of my build.
Old 03-19-2005, 07:24 AM   #6
hangsupra
:lol: i havent got that problem before....i cant help...hope someone else could....
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
Quick release hub adapter!? 88Supraboy MKIII Supra 4 03-04-2006 04:10 PM
Quick release hub adapter 88Supraboy Non-Generation Specific Questions 0 03-02-2006 01:55 PM
new to forums... some quick Q's gfx MKIII Supra 3 10-12-2005 01:54 PM
