Old 03-30-2006, 06:48 PM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Default Which NGK Spark Plugs
What's the word on which NGK's to use in a turbo--platinum or the newer iridium?
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 03-30-2006, 06:58 PM   #2
dcrusupra
dcrusupra's Avatar
Iridium is better IMO
New Rebuild
My CarDomain
Old 03-31-2006, 12:04 AM   #3
Burn N' Up
Burn N' Up's Avatar
Iridium is better, and there are two types available. IF you go to Supra sport they sell both the difference is;
to quote Charles Britz of SupraSport.com "The difference is in the heat range. BCPR5EIX11 3306 is a hotter plug meaning that there is more electrode exposed. You can use this plug with basic performance upgrades but when turning up the boost the BCPR6EIX 5689 is a better choice because it is colder. With the higher temperatures with a turbo charged engine could cause the hotter plug to fail or cause preignition."
Old 03-31-2006, 02:51 PM   #4
Benesesso
Benesesso's Avatar
Picked up a set of NGK Iridiums yesterday. $6.95 ea.
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Issues After Changing Spark Plugs Getphazed MKIII Supra 8 11-03-2006 12:31 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
