Old 03-07-2006, 06:10 PM   #1
XtreeX
XtreeX is on a distinguished road
Default Starter problemo
Ohk, I have a python security system with 'fail safe' ignition. Yesterday I set off my alarm by hitting the panic button on accident and couldnt shut it off other then turning the key in the ignition. Everything is disabled im pretty sure, or disarmed i should say... and my electricity and power works fine. I turn the key and nothing happens. What would this be? Starter? If so, is that something i can replace myself?
Thanks in advance
XtreeX is offline   Reply With Quote
Old 03-07-2006, 06:11 PM   #2
hangsupra
does your car alarm have a kill start
Old 03-07-2006, 06:12 PM   #3
XtreeX
Yea thats what i meant... But I talked to the installers at Circuit CIty (where I work) and they helped me over the phone and everything should be disarmed. I think that it may just be a coincedence?? i dunno
Old 03-07-2006, 06:16 PM   #4
XtreeX
need help STAT! I do not want to have to tow it to a mechanic, but its looking grim... boo
Old 03-08-2006, 10:21 AM   #5
XtreeX
any ideas? (bump)
Old 03-08-2006, 05:33 PM   #6
dcrusupra
dcrusupra's Avatar
Open the trunk with the key, lock the doors and unlock it with the key? That usually resets the stock alarm, not sure about an aftermarket alarm tho.
New Rebuild
My CarDomain
Old 03-08-2006, 07:15 PM   #7
XtreeX
the driver side and hatch keyholes are dead. the passenger side one works but it is an aftermarket alarm so i dont think that will work. hrmm... ill keep trying.
Old 03-11-2006, 12:28 AM   #8
XtreeX
Ok. Well, the ignition and the starter both get power. But the ignition still wont even attempt to start the engine. I think maybe its the RELAY somewhere. Becasue I hear no clicking whatso ever from the lower kick panel fuses/relays. So I dont think its the security system. We tried connecting the two starter wires and nothing turned over.
This is really starting to piss me off. The installers think its the car and my mechanic thinks its the security system. Toyota is a last resort. Anyone have any ideas?
Anyone know where the ignition/starter relays are?
Thanks
Old 03-11-2006, 01:57 PM   #9
nickvash0104
nickvash0104 is on a distinguished road
The starter relay, if I remember, is on the passenger side kick panel. You'd have to remove the plastic cover (there is a nut on a stud that holds it in) and the junction block is along the right under the glovebox. If I recall correctly, the OEM starter relay is a green relay, four pins, square in shape. I'd post a link to the TSRM, but they're down at the moment. I know it's listed in the Body Electrical section.
--Nick
Black '87 N/A Auto
nickvash0104 is offline   Reply With Quote
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
90 mkIII starter connections doodah MKIII Supra 1 11-11-2008 06:14 PM
How to quickly test starter CyFi6 MKIII Supra 4 11-30-2007 01:57 AM
Starter Relay? Passenger Kick panel? dannydavi MKIII Supra 8 09-24-2007 01:12 AM
starter removel? swied MKIII Supra 4 04-23-2007 04:50 AM
