Old 09-13-2006, 09:11 PM   #1
Reeves
Reeves is on a distinguished road
Sorry to ressurect an old thread but i really want to know some things about chips. I was told that when upgrading your car with exhaust, intake, and whatnot, the computer will get used to it, "learn", and adjust itself and you will lose much of the horsepower from the mods. They told me a chip will take care of that.. You guys make chips sounds really bad, while a co-worker of mine says they make your car run more effecient and gives you more horsepower at the same time.
Basically just want to know if there are any "safe" chips for our cars. And if not is it true that the computer will adjust to our mods making us lose horses?
Reeves is offline   Reply With Quote
Old 09-14-2006, 02:34 AM   #2
cars4me89
cars4me89's Avatar
cars4me89 is on a distinguished road
What I want to know is that.. if you make the car run richer by using that chip and making it think its getting more air than it is.. and it dumps in more fuel cause of it thinking its getting colder air. So then it puts that extra fuel in and some of it won't burn up. that means the car is now running rich. why wouldnt the oxygen sensor pick up on that and change the injectors to make it run at that ideal 14.7:1 ratio. If I'm correct that would make the chip completely obselete and would in fact do NOTHING. am i right??
1987 Toyota Supra 7M-GE Natrually Aspirated Automatic
http://www.cardomain.com/ride/2385905
Currently enrolled in UTI (Universal Technical Institute.. ya ya say what you want bout the school lol its got some nice benefits though), have about two years of auto experience so far.. only 18 years old. My supra's older than me :P
-Phil
cars4me89 is offline   Reply With Quote
Old 09-14-2006, 03:19 AM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
the only modification that your ecu does really is ignition timing (usually retarding due to faulty knock sensors or pinging is actually happening) or air fuel ratio
how it does this is through the 02 sensor, if too much oxygen is detected in the exhaust gasses it will richen the fuel mixture to compensate (if it can... it depends on what is wrong) or if it detects not enough oxygen it will back off the fueling to compensate
the ecu doesn't really know what mods you have or are doing to it, all i can see is extra air in which case it will richen where needed
you do not lose power by doing mods, else why would people mod their cars?
and CHIPS ARE RUBBISH!
/chips thread
Pics of my build.
Do a diagnostic first!
Old 09-14-2006, 03:23 AM   #4
suprra_girl
7M POWAH! ;)
if that chip makes the car run richer it does not automatically make the ecu think that there is more air, you're forgetting an important item which is at the beginning of your engine.... an "Air Flow Meter". That will tell the ecu exactly what air is entering the system, unless you have a boost leak which is of course not the afm's fault.
yes you are correct the 02 sensor would send it's readings to the ecu to which it analyses and corrects
Pics of my build.
