Old 02-14-2006, 09:59 PM   #1
johndawn
johndawn is on a distinguished road
Default i have a starting problem
when the car is cold it will start but then it cuts out, when you start it again and rev it for about 3 min it works ok also there is a orange light come on the dashboard which looks like a little engine my car is a toyota supra 1989 3L turbo auto many thanks dawn
p.s hope any one can help me it is driving me mad.
johndawn is offline   Reply With Quote
Old 02-14-2006, 10:18 PM   #2
mrnickleye
mrnickleye's Avatar
The little light, the one on the far left of dash, is the 'low coolant' in the plastic overflow bottle warning. Fill the bottle 1/2 way.
The start probplem is likely you cold start injector circuit. The sensor may be disconnected or not working. Or the injector itself may not be working.
Check the TSRM fo test proceedures.
http://www.cygnusx1.net/supra/library/TSRM/
Old 02-15-2006, 04:24 PM   #3
johndawn
Default where would i find the cold start injector
thank you for replying to me where would i find the sensor or the cold start injector if you could tell me. many many thanks dawn
Old 02-15-2006, 07:51 PM   #4
dcrusupra
dcrusupra's Avatar
I believe the cold start injector is at the top of the intake manifold right in the center after the throttle body. But i may be wrong.
New Rebuild
My CarDomain
Old 02-16-2006, 01:16 AM   #5
mrnickleye
mrnickleye's Avatar
Smile
http://www.cygnusx1.net/supra/librar...fi/FI_002.html
See this section for diagnosing.
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
mysterious starting problem stevanom MKIII Supra 7 11-14-2006 08:50 PM
starting problem Supraman MKIII Supra 8 09-26-2006 09:53 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
problem starting damdog05 MKIII Supra 0 08-05-2006 02:44 AM
