Closed Thread
Old 01-31-2005, 12:01 PM   #1
WHITETURBO
WHITETURBO is on a distinguished road
My heater did not work. I tracked it down to a bad vsv ( part # 084600-8980). This selonided
opens the valve that lets the hot water runs through the heater core. I bypassed the valve (it is always open now) and the heat works - Can this heart anything? Also, does any body have a spare or can tell me where I can buy one for a reasonable price.
WHITETURBO is offline
Old 02-06-2005, 11:59 AM   #2
well i wouldn't expect it would hurt anything... i think i have it bypassed as well and no probs....
i'm sure someone else has one somewhere
suprra_girl is offline
Old 02-07-2005, 11:49 PM   #3
solomaster2002
solomaster2002 is on a distinguished road
it does not hurt if you just bypass it
i have heard that the only purpose for this valve is that it shuts off fluid to the heater core only when the a/c is on high
im not totally shure maybe someone else can correct me but i have mine removed and it works great
solomaster2002 is offline
Old 03-07-2005, 08:35 PM   #4
1989MKIII
1989MKIII is on a distinguished road
hey all,
im new here, just joined today and i have posted some stuff, but anyway, my heat does not work eather, and i was wondering where is this "vsv" vavle thing to bypass, and how did you do it. if you could let me know. so i can try it and by pass mine. caz down here in Missouri USA its kinda kold during these months sometimes. let me know
thanks for yalls help
justin
1989MKIII is offline
Old 03-07-2005, 10:10 PM   #5
87supraguy
87supraguy is on a distinguished road
i have mine bypasssed as well and it hasnt hurt anything since its been bypassed. the vavle is right against the fire wall on the passenger side. two heater vhoses go into it and a vacuuum line as well as a wire plug. to by pass it take the two tubes off and buy a little piece of plastic piping(bought mine at a parts store and its made dor connecting heater hoses together it was like $5) conect them together and clamp it on and thats it.
new VSV from toyota is about $150 us. there are no after market parts for it that ive found
87supraguy is offline
Old 09-03-2011, 01:11 AM   #6
thadave06
thadave06 is on a distinguished road
Default 87 supraguy, vsv solution
Thanks for the information. I own a 1989 Supra turbo and the problem has been fixed. Now I have heat. Replacement part way too expensive. Thanks again
thadave06 is offline
Old 02-13-2012, 07:54 PM   #7
pa32mays
pa32mays is on a distinguished road
If its just the electrical VSV not working, you should be able to just port the vacuum direct to the diaphragm and not have to mess with the heater hoses.
1987 Supra Turbo Targa 5spd 7M-GTE Black/Grey 156kmiles
pa32mays is offline
Old 02-13-2012, 08:13 PM   #8
EDIT: I didn't realize that the VSV wasn't covered in this thread.
In the MKIII FAQ you'll find a much more detailed thread about the VSV and blower resistor. I didn't like the thread that was in the FAQ, I've replaced it with one with just the relevant information.
No heat? The two most common problems HCV VSV and blower resistors.
cre is offline
Old 02-25-2012, 07:11 AM   #9
bandit1730
bandit1730 is on a distinguished road
Default $35.00 Low-Cost Toyota Solution to VSV replacement
Had the same problem with the VSV solenoid being busted on my 89 turbo. Searching on the net, came around this post http://www.supras.com/06/techcenter/display.php?QID=58 . The part costs around $35.00 from Toyota (for Camry). It is the same solenoid, but the connector is different. Just cut the old VSV connector/wire as close to the VSV as possible and solder two standard female connectors (like the ones used on speakers) and you are good to go on the freezing cold.
Toyota part # 88690-32280
bandit1730 is offline
Old 02-25-2012, 07:56 AM   #10
Thanks, copied over to the thread in the MKIII FAQ.
http://www.toyota-supra.info/forums/...resistors.html
cre is offline
Closed Thread
heater valve octron MKIV Supra 10 11-29-2006 02:54 PM
