#5 |
I too have seen a loose crank pulley sound like a rod knock, on a couple of cars.
Rod knock develops due to the bearing(s) on the rod that attach it to the crankshaft, getting too much clearance (gap, play). It can happen when the oil LEVEL gets too low, and you go around a corner and the pump doesn't pick up oil for a moment. Lack of oil at the bearing is the cause. Oil quality plays a role. If the oil level NEVER got low, but has not been changed for too long, it won't lubricate very well. Repeated high RPMs stress the bearings. I change my oil every 2k, just to be safe. Oil is still cheap enough, and cheaper than engine work.
Had a Red 1989 N/A. Automatic. Sports Pkg. w/wing. TEMS, and some nice MODS. Sold to a friend 10/08/08. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Picture Of Knock Sensor Locations | ravenmaster | MKIII Supra | 10 | 01-31-2012 03:37 PM |
| Starting isssues and spark knock Q's | spudz29212MKIII | MKIII Supra | 65 | 05-30-2008 06:44 PM |
| Engine knock @ 1700-2300 | rstutler | MKIII Supra | 8 | 03-07-2008 07:36 PM |
| Rod knock?? | wetwilly | MKIII Supra | 8 | 02-25-2006 04:00 PM |
| Knock sensor..........ebay. | rnoswal | MKIII Supra | 0 | 11-06-2005 07:24 PM |
